Question about Maytag MMC5000 Microwave Oven
The Daewoo 2m218 magnetron in my microwave is starting to malfunction. It smells like it is burning up. I found a magnetron fot it on ebay for 30 dollars. Would it be a good idea to replace the magnetron or just buy a new microwave. Microwave plus trim is about 290 dollars.
MicrowaveSvc
  • 9098 Answers
SOURCE: Daewoo KOC1B0K
In that case, the most likely problems are:
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 21, 2008
  • 4088 Answers
SOURCE: my microwave does not heat and i was told it was
Look for a popped fuse which usually blows when the magnetron goes south. The HV diode occasionally shorts out which will also blow the fuse. The large capacitor can short out as well, but not too commonly. If the transformer goes bad, you can usually smell it. When you test the oven, be sure to have a 'load' in the oven (a glass of water) to prevent arcs and sparks. If you get it seeming to run, but no heat, check the 'stirrer' fan bearing (in the waveguide just before entering the oven cavity) which can arc-through and short-out the microwaves. It would be nice to have a 10kV DC meter to check for the 5-6kV (negative) required to operate the magnetron. You are probably beginning to see why such a high labor charge is levied. Hope this helps!
Posted on Nov 17, 2010
  • 958 Answers
SOURCE: Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Posted on Feb 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag microwave OVER the stove
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or a friend can use for test help, but read their safety warnings first:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
freetek
  • 5568 Answers
SOURCE: Replace a magnetron tube
Magnetrons cannot be 'repaired,' only replaced. While the cost of them has decreased by about 75% over the last couple of decades, the parts you receive are often inferior to the original and will show this only after installed and operating and then the time required for different tasks may be much longer.  Unless there is something unique about the unit, I advise replacing it.
Posted on Nov 02, 2008
Sharp microwave burning smell
Replace the microwave oven, the problem is the magnetron, "heart of the system" and the most expensive part.
May 04, 2012 | Sharp Microwave Ovens
My GE model JVM1631WB002 is giving off a burning smell. What can I do?
A burning smell is usually a sign of a bad magnetron tube, the microwave source. As they age they take more power, and this causes excess heating that can cause the smell. Eventually the tube burns out and you get no heating. If you've been noticing longer than normal cooking times, it's due to the weak tube.
You can replace a magnetron, but it's a costly part (around $100-$125) and the repair should be done by a professional because of safety concerns. (Several websites describe how to replace a magnetron if you'd like to try it yourself, but you need to be very careful. MICROWAVES USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU.) Between the part and labor costs, when the magnetron goes bad it's often more economical to spend a little more and replace the oven.
There are some other parts that can get hot and sometimes smell, but the magnetron is most common. If you want to keep the oven, I'd suggest letting a professional check it over and give you an estimated for the repair. Then you can decide what you want to do.
Jun 06, 2011 | GE JVM1631 Microwave Oven
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
Gold Star 1515W microwave not heating up and when
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Goldstar MV-1515 Microwave Oven
Stoped heating and had a smell like somthing electrical was burning? Fix it or buy a new one?
HI, normally, when you smell the burning electrical wires and board components, this will confirm a major capacitor malfunction. in this case, all electronic component will be fried or destroyed. these parts are the running diode,magnetron tube,cut-off fuse,noise filter and control board as well. all these parts will be costly to replaced, and it will be more cost effective to just cut your loss and purchase a new unit. the newer unit will be cheaper than the actual repair bill in this case.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Smell of burning in my daewoo microwave oven. It has never been used before
Daewoo make some cheap microwave ovens. I have one, and it is rubbish. It came fitted in a new caravan, and because it decided to keep cutting out after only a few minutes of use, it was replaced by another that had the same problem. I know it's a cheap oven, but it should work. I wouldn't recommend this to any caravanners, and would recommend a different make.
The smell should go when the Daewoo goes!!
May 03, 2009 | Microwave Ovens
Malfunction microwave Daewoo KOC995T
I would say you have a problem in the high voltage section, such as a loose or corroded connection at the magnetron or a bad magnetron.
Aug 19, 2008 | Daewoo Microwave Ovens
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Maytag MMC5000 Microwave Oven Logo
2,247 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
