Question about Reddy Heater-170,000 BTU Kerosene Deluxe
WHAT IS THE CORRECT NOZZLE SIZE ? - Reddy Heater-170,000 BTU Kerosene Deluxe
  • 232 Answers
PP223 is the correct nozzle for all 170T Reddy heaters. Click on this link.
Posted on Nov 06, 2010
I have a 2014 dodge charger and I cannot get the gas nozzle to go in to refuel...HELP
Ah well are you using the correct fuel type make sure you using the gas and not the diesel pump they are different sizes .
Apr 02, 2016 | Dodge Cars & Trucks
How do I clean head nozzle?
Using the printer control panel
1 Load plain Letter-size paper.
2 From the printer control panel, press , and then press .
3 Press the arrow buttons until Clean Cartridges appears, and then press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
4 Print the document again to verify that the print quality has improved.
Oct 11, 2014 | Lexmark X4690 Wireless InkJet Printer
I just got a Dewalt DXPW 3425 do they have a less powerful spray tip than 40*. Or is there a way to adjust the spray to a much lower output for more delicate deck woods? Thanks Mike in Oregon
Tips are described with two numbers. There is the "size" in gallons per minute and the spray angle in degrees. If you increase the nozzle size the pump sprays the same amount of water ( they are positive displacement pumps) but it will come out at a lower pressure. If you increase the spray angle you decrease the impact pressure over a wider area. A zero degree nozzle has the greatest impact on the smallest area. The largest spray angle is typically 40 degrees and has the "softest" impact. There are lots of nozzle charts online that will tell you the pressure output at various sizes and gallons per minute. Usually paint supply stores have nozzles and can help you get the size you want.
Another way to decrease the power of the spray tip is to simply hold it farther away from the target. The pressure decreases by the square of the distance. ( moving the tip away a little decreases the impact a lot) Experience helps with this technique. Start with the tip a foot away and slowly move it closer to get the maximum cleaning with the minimum damage to the deck. You have to be careful or a momentary lapse of concentration can lift the grain of the wood in a second. The nozzle size is much more fail safe.
Going to a larger nozzle size and wider angle is better than adjusting the bypass valve.
Oct 09, 2014 | Garden
How do you adjust the pressure?
get larger nozzles, if you are using size 4 nozzles now ( looks right for 3 gpm at 2500 psi) then you would use size 4.5 for 2000 psi, size 5 for 1600 psi etc
Chart here https://www.stens.com/assets/media/pdf/2012_Nozzle_Size_Reference_Guide.pdf
Sep 07, 2014 | Dewalt Pressure Washer - DXPW3025
Kacher machine K2.98
So when you are using the machine & keeping the trigger pulled open the machine builds up to pressure then knocks off all the time.
If this is so the machine is not at fault & is doing what it is meant to do & protect its self from over pressuring & the fault is in the nozzles you are using.
You need to check the nozzle size is correct for the machine & also airline the nozzle to clear of any dirt.
Thanks qwashers
Mar 22, 2014 | Karcher PSI Electric Pressure Washer
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
Colour ink not printing
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the "Ink" option in the printer driver may be set to "Black" instead of "Color" or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged.
A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, turn the printer off overnight and try the cleaning cycles again.
Try a new ink cartridge. Also, make sure you are using a genuine ink cartridge and has the same number as your old catridge.
Jun 20, 2011 | Computers & Internet
How do you clean the nozzles
For Windows users Follow the steps below to use the Nozzle Check utility.
1 Make sure that A4 or Letter size paper is loaded in the sheet feeder. 2 Access the printer software. If you need instructions, see Accessing the printer software. 3 Click the Utility tab, then click the Nozzle Check button. 4 Follow the on-screen instructions. For Macintosh users Follow the steps below to use the Nozzle Check utility.
1 Make sure that A4 or Letter size paper is loaded in the sheet feeder. 2 Access the Print or Page Setup dialog box. 3 Click the Utility icon button, then click the Nozzle Check button. 4 Follow the on-screen instructions.
Jan 11, 2010 | Epson Stylus 880 InkJet Color Printer
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Aug 12, 2009 | Porter Cable Gravity Feed Paint Sprayer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
80 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
