Question about Sony PlayStation 2 Slimline Console
Loading switch HI i broke off the loading switch.Do you know a way to override it or an other solution?
    Scholar:
  • 65 Answers
Yes i do know the solution but you need to be very careful about that.
That switch actually is a lid protection.That is important because allow the disk to start spinning and recognize the the door closed.
You can bypass that making a bridge soldering connection.Use a voltmeter in ohm and check which leg are connected, i do believe the 2 on the top need to be soldered togheter and the 2 in the bottom.
Good luck.I did few time since there is not spare part available so far and it`s working
Posted on Jun 19, 2008
Where is the override spring loaded button in a 1997Ford expedition
Do you mean fuel shut off switch ? It is called inertia fuel shut off switch .
Inertia Fuel Shutoff Switch C204
Behind right side of I/P
Do you know what the right kick panel is ?
Mar 18, 2016 | Cars & Trucks
Igntion switch broke need to remove
Hi Anonymous, I would be glad to help you but I need to know what year and model your bike is? Thank you.
Mar 17, 2014 | Harley Davidson Motorcycles
Ti04 clock rotates and new trippers but doesn't turn on
You probably have T104 timer.
Clock rotates so power to timer motor is good. This means 240Volt breaker is good.
Use override lever and see if Load (light, fan, motor) turns on and off. If override does not turn Load on-off, then bypass timer and see if load works. Move wires from terminal 2 to terminal 1, and terminals 4 to terminal 3.
Did you order correct trippers?
Copy following links for Intermatic troubleshooting and Intermatic parts list.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
I have the Intermatic T-104. Hate to toss things out if it's just a minor problem. The timer keeps accurate time. The "on" switch doesn't work; the "off" switch does. I...
Open following link to determine if timer is bad:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Key things are clock dial rotating on timer, and manual override lever turning load ON-OFF.
If clock motor is rotating and keeping good time, then you know that timer is receiving 240Volt from circuit breaker.
Check for loose wiring, and then check if you have 240V across terminals 2 and 4.
If you have 240volt across terminals 2 and 4, then that says 240V is going to Load, and that load is suspect.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Buy cheap multimeter from hardware: set multimeter to read 240 or 250V, and put test prongs on terminals 2 and 4, and then move override lever and test again.
Safety: Tape multimeter leads to wood sticks to keep hands away from power. Stand on dry boards. Use adequate light.
If timer is genuinely bad, then you can buy timer insert: T104M
Usually it is cheaper to buy whole new T014, and then snap new mechanism into old box.
Aug 12, 2011 | Intermatic T104 24h 208-277v Mechanical...
Where can I find the manual for the Intermatic Incorporated Timer, Spst-125V 24Hr Mechanical 2 On/Off - PB913N84
There is no manual specific to the PB800-900 series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
Timer uses 107TTN222 ON tripper and 107TN221 OFF tripper.
Push trippers onto dial at times you want timer to turn on-off.
Rotate dial until current time lines up with arrowhead located in center of timer dial.
images show that timer has override knob that can be rotated.
Timer has 4 terminal connections. 2 connections are for 120Volt clock motor, and 2 terminals are the switch for turning Load on-off.
Black hot wire and white neutral wire connect to clock terminals.
Switch terminals are dry.
Dry terminals mean they have no power when wires are connected to clock motor.
The switch terminals wire just like ordinary light switch: Power connects to one of the terminals, and wire to Load connects to other terminal. Neutral wire does not connect to switch terminals, just like wiring an ordinary light switch.
Offhand I do not know which set of terminals is for clock motor.
Use continuity tester on each set of terminals.
Clock terminals will show continuity at all times, no matter which position override knob is set.
Switch terminals will show continuity with override knob in one position, but not the other position.
Jul 04, 2011 | Intermatic TIMER,SPST-125V 24HR MECHANICAL...
Lost the key to my ducati monster 2002. How can I start it?? I'm impatient and don't want to wait I already broke the ignition I got it to switch on buy it won't catch
it varies based on model, you'll need to let us know which you have. Some have an interlock system, that may be difficult to override.
Jun 04, 2011 | 2002 Ducati Monster 900 i.e.
Time wheel stopped moving.
You posted under the Intermatic T-101
Troubleshoot:
Check if manual override turns Load on and off
If manual override snaps clean and crisp, and Load operates correctly, then you can replace the clock motor.
If manual override does not work very well, then you can buy another T-101 and swap out insides without changing box.
If manual override snaps clean and crisp, but Load does not come on, then check your electricity at breaker and check if wires are tight inside the timer.
Clock Motor
T-101: replace with T100series 120Volt clock motor
T-103: replace with T100series 120Volt clock motor
T-104: T100 series 240V clock motor
Where to buy clock motor:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to replace clock motor:
Turn off power.
Take a photo of your wiring so you have a record of how wiring looks.
There are two small white wires that go to clock motor.
Inside box, there is a release lever located top of box.
Push release lever up and timer mechanism tips out.
Lift mechanism up slightly, and then tip all the way out.
Clock motor is held by tiny screws or tiny star-screws
Swap motors.
Attach clock motor wires on front terminals in exact location they were connected before.
Turn screw terminals very tight against copper wire.
Nov 04, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
New 220 timer put in ,wont turn on.Vsiual chek working and its keeping time,switches look good but woont kick on?
I wish I knew the model number.
maybe the wiring is wrong, but different model numbers have different wiring.
I wrote a page on each the T-104 and T-1906 240V timers:
It shows the wiring for 2 common Intermatic timers
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
Now let's troubleshoot a bit:
You say the dial is rotating around.
And the dial has tripper pins in place.
What about the manual override? Does the manual override turn lights on and off?
If manual override does not turn on the Load, then your wiring is suspect.
If manual override works, then your wiring could still be wrong by one wire.
Check your tripper pins.
Are they attached and set exactly right?
Are you using both ON trippers and OFF trippers?
1565897.jpgThe OFF tripper pushes a lever. The lever is connected to Manual override. Click manual override to see if timer can turn Load ON-and-OFF
Up-vote if this information helped. Thanks for the feedback.
Oct 14, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Power is on but wont start
well without knowing any other info, the 'door open' safety override switch has probably shorted so when you close it it does not complete the circuit. I would have that switch replaced, its like a $2 part and see how it runs. If this doesn't do it, you'll need to give some better details
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Sony PlayStation 2 Slimline Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
