Westinghouse monitor model lcm 19w4. Screen keeps going black and you have to turn it off then back on to get screen back. Sometimes screen will work properly for hours, but sometimes keeps happening every couple minutes or even only a few seconds at a time. Carol
    Novelist:
  • 150 Answers
This looks like a power supply problem, due to internal
over heating. When it cools down, the power supply turns
back on, or an "over current/ thermal" protection circuit
trips. Shutting of the monitor off resets it, and then it trips
again.
I had an old Samsung 19" with an identical problem.
(see my other post)
Mine was caused by a leaky capacitor, but every
monitor is different. (I have considerable knowledge of
electronics, as well as a degree in engineering, so
I was able to fix it, but I would not recommend this to
a non-tech person.)
The 19w4 seems to be a fairly new wide format monitor,
probably still under warranty. I would take it back to the
store on a busy Saturday afternoon and scream blue
murder.
There is absolutely nothing you could have done to cause
this problem, nor is it normal wear and tare.
It is the result of sub-standard manufacture, and you have
every reason to take it back. Your case is stronger if
you don't try to open it.
Good luck, Martin.
please rate my answers.
Posted on Jun 14, 2008
The monitor Westinghouse model LCM-19w4 when I turn on the computer the screen remains black even with a green light on and I can use a flashlight to see the screen. When I turn it on and off the scre
It's mostly likely a bad capacitor in the main power supply of your monitor. If you're brave enough to dismantle it, look for capacitors that're "crowned", and sometimes even rupture from overheating in such circumstances. You can order replacements from Digi-Key if you can figure out which might be your problem, but I'm not sure I recommend you try this unless you have at least SOME soldering/desoldering skills or a friend who does. You COULD wind up worse off. It's up to you, only YOU know your personal skill level for such tasks. And do I need to say, UNPLUG it before dismantiling? :)
Mar 16, 2014 | Westinghouse 22" Widescreen LCD Flat Panel...
Lcd-17v8 monitor power won't stay on. westinghouse monitor
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
Sep 06, 2011 | Gateway FPD2275W LCD Monitor
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
No image on monitor model LCM- 19v7
Look for bad capacitors (bulging top/seal) in the power supply first, post back what you see inside so we can guide you further, see example of failed Westinghouse monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
My computer screen goes black
You have either a bad inverter circuit board or burned out backlight fluorescent bulb.
Jul 02, 2009 | Westinghouse LCM-19v1 Monitor
Westinghouse LCM-19w4 has power, but blank screen
refer to an earlier post about similar problems. Does it power up and then shut itself off. this is possibly due to two defective capacitors. 27 cents on line $1.50 at radio shack. They will be puffy on top. I am a complete novice to soldering a capacitor onto a board. but since I was junking the monitor otherwise I gave it a try. It's still working after sitting idle a year. Handy advice on soldering online. use copper wire to **** up the old solder and try not to fry the capacitors or the board. If I did it anyone can.
Mar 22, 2009 | Westinghouse Computers & Internet
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
My Westinghouse LCM-19w4 Monitor will not turn on,..it just blinks and nothing
I just repaired my LCM 19W4. My symptoms were a little different; the light was not on or blinking like yours. I replaced two bad capacitors today (220 uF 25V High Temp) So far so good. Bad caps can be easy to identify; they are slightly bulging at the top. Soldering can be very tricky though. But just like plodder said, make sure it's the monitor that's bad and not something else by hooking up a known working monitor first.
May 18, 2008 | Computers & Internet
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
