You don't need additional software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
SOURCE: I have the fuji finepix
I agree with jackboy. Remove the Fuji software, and let windows locate the camera via the USB port. I recommend to my customers to only use the Fuji Finepix Viewer software if they are having trouble after using the Microsoft software already installed on their computer. Try to avoid the Fuji software if at all possible. Not that there is anything wrong with it, it's just usually unnecessary, and can cause conflicts, possibley like what you are experiencing.
SOURCE: fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac. I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
SOURCE: Need download manual for the Fuji finepix J10 digital camera
u can download here
http://www.scribd.com/doc/3497987/Icom-IC910H-Service-manual
SOURCE: I have windows XP and can't upload photos from my
In order to download photos to your PC or laptop, you have to install the drivers for your camera. Please follow these steps.
1- Use the CD which came with your camera and install the drivers. If you do not have your CD, go to fuji website and download it.
http://www.fujifilm.com/products/digital/download/01/index.html
2- After installing the drivers, connect your camera to your computer and on the dial select play and turn the camera on.
3- If the drivers are installed correctely, when you click start, computer you would see an icon with all or part of Fuji FinePix J10 Digital. Double click on this icon. You would see one or more folders which contain the stored pictures or videos. Now you are able to download, copy delete the stored pictures in your camera.
SOURCE: Can I charge the battery in Fuji FinePix J10 with my PC?
Nope. Gotta use the supplied external charger. Won't charge via USB, if that's what you are hoping.
