Question about i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case
Dropped hard drive
Hi, I recently dropped my irocks hard drive from about 20 inches while off. The next time I went to use it the device turned on and began spinning but made a clicking noise and would not show up on my computer. Anything I can do to fix it or at least get the data off of it? Thanks.
Jay
  • dhmtbj Jun 14, 2008
    How would I go about doing that if I can't get the device to show up on my computer?
  • kingkesq2000 Aug 24, 2008
    What does the case have to do with it? I dropped mine from about a foot and now it turns on and starts spinning bu then stops. the computer is not reconizing it or anything. is it any good now or can I fix it?
  • 2,794 Answers
You can try using Ghost to back the data up. It sounds to me like a head crash.
Posted on Jun 14, 2008
  • Tim Babcock
    Tim Babcock Jun 14, 2008
    Your going to have to get the device to show up.
    You could try putting it into another case and see if it recognizes it.
Hard drive is showing up as an composite device
This method prevents your USB external drive from powering down.
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
hope this helps
Jun 23, 2012 | Western Digital My Passport Essential SE...
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Afte connecting as shown on the printed sheet with the new product how do es one go about dragging and dropping folders of files into the device and how does on access the material once copied to your...
to drag and drop files into the device is quite simple. First allow the unit to install on your device. After it has been successfully installed open the device on a window and at the same time open the location from where you want to drag from on another window leftclick on what you want to drag and pull it to where you want to drop.
Hope this solution has been helpful?
Mar 11, 2011 | Western Digital Wd Elements Se 1tb...
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Hard drive error
same exact problem let sit for several months went to turn on and all i could see was a "hard disk error" message flash very quickly and then turn off. after months of no help online i decided to open
my jukebox 20 and there are 4 ni-cad batteries inside. i removed batteries and replaced with 4 "AA"
regular energizer batteries and it works fine. at least until i extract my 1000 songs and put them on another device so i ll never lose them. GOOD LUCK.
Mar 08, 2009 | Archos Jukebox Studio 20 MP3 Player
Hard Drive Dropped
Hi there
You may want to try going to add new hardware and see if scanning for hardfware change will let it recognoze the device if not uninstall it under device manager and have it reinstall the device upon start up of the pc
Jan 03, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Maxtor Hard drive tries to work
I had this problem also. It was either dropped or something fell on it. You have to get it repaired or a new one. If you have VERY important information that cannot be replaced, consider a data recovery service from your local stores.
Good luck with your Drive.
Aug 14, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
IRock 860
I have an 860 I'm trying it now. Actually I was on trying to find the original software which seems to be nowhere. Saw your question and thought I'd try ITunes.
Jul 07, 2008 | FID Irock 830 128 MB MP3 Player
Open Questions:
i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case Logo
591 people viewed this question
Top i-rocks Computers & Internet Experts
micky dee
Alan Rothery
Willem.
Willem.
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
