Question about EnGenius Technologies ECB3500 802.11g High Power 600mw Access Point/client Bridge/repeater/router/wd
I have the ECB3500. I have been trying to set this up in repeater mode. I've been through the settings several times and can not determine what the problem is... I changed the unit password, switched modes to repeater and have tried both static IP and DHCP. Security I've left disabled as I extended an unsecured network. I entered the SSID to match original network and have also selected hex ID under the site survey. The problem I'm having is after the ECB3500 boots up I see a boost in the signal strength. All looks good about 10-15 seconds later it shows the network as limited and local access only. If I unplug the ECB3500 I will get local and Internet, I've been through the user manual and settings several times and don't know what the problem is.
  • 55 Answers
Try to use dhcp only from primary router - modem. For the repeater disable dhcp. Ip's let auto. if i was helpful please vote...
Posted on Nov 05, 2010
Which program and settings should I use on my En Genius ECB3500 for rental homes?
For your current router you want to set the following options to optimize your wireless network and make sure it runs stable:
Security mode: WPA2 with AES
Channel mode: manual
Wifi Channel: 11
In order to extend the range of your wifi network you will want to get an access point, or a second router and configure that one as an access point.
Dec 06, 2013 | EnGenius Technologies ECB3500 802.11g High...
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 | Watches
    I'm trying to connect the ecb3500 as an AP Router to get wireless access from my cable modem. THe old LinkSys worked fine, although it has low power, but the ecb is unable to connect (status of connection...
    ECB3500 Can I downgrade firmware safely with this product?Yes. I cannot get into the device from my computer. What is the basic setting check?
    - Make sure you are directly connected to the unit.
    - Do not have a switch or router in between and do not connect wirelessly.
    - Make sure your power injector/adapter is on, power is going to the unit, and the "network" side is going to your computer.
    - Make sure your computer is set to a static IP address of 192.168.1.10.
    - Type in 192.168.1.1 using Internet Explorer.
    How to change the IP Address?
    The default IP address is 192.168.1.1. This IP address is typically in conflict with many routers out in the market. You will need to change the IP address manually to an IP address that is different but part of the same network. This means if your router IP address is 192.168.1.1, you should change the device to 192.168.1.2, for example. We recommend you change the IP address before other settings. You change your IP address in the "LAN" section in the GUI.
    How do I reset the device?
    Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
    How do I set up AP WDS Repeater?
    Click here for instructions.
    How do I set up the device under Apple MAC OS X environment?
    I cannot connect or maintain a log in to the device.
    We recommend using internet explorer with at least IE7 or higher. Make sure you have latest version of Java script.
    What distance in kilometers (km) should I set the device to?
    Default is 1km. If you are setting up long distance point to point links, the time it takes the radio wave to get there needs to be considered for proper handshaking (ACK response). This window should be accurate within 5 kilometers. In other words if you have a 5 kilometer link, ideally you should set it to 5km, but a setting of 1km to 10km should keep you in an acceptable window. For short distances, keep this to 1km.
    What is a point-to-point link setup?One unit would need to be in AP mode while the other in CB mode. The AP should be connected directly to the routers LAN port, and the other will be in Client Bridge Mode linking back to the AP. The Client side will then provide a WIRED connection for users of the remote location. You can choose to connect this wired connection to just one PC, or to a switch, hub, or another wireless access point for multiple users at the remote location. What is a Client Bridge (CB) Mode?
    A client connects to an access point. Your laptop is a client. A bridge is something that connects two "wired" networks together. A client bridge therefore is a radio that wirelessly bridges two networks. The Ethernet port of the 2610 in CB mode provides the wired connection to the remote location. This Ethernet port can directly connect to a single PC, a hub, a switch, or another router.
    What is considered a "good" signal?The signal meter is not available in AP mode. In CB mode, under connection status, a signal of -74dbm or better is a good signal. It's important to understand which direction numerically is a better signal. Dbm's are referenced to 1 milliwatt. 1mW = 0dbm. A stronger signal would be a positive number and a weak signal would be a very negative number. For example, a -50dbm signal is stronger signal than -92dbm. What is spanning tree protocol?
    When there are several possible paths a packet can route to (redundant links for increased reliability for example), a loop can occur (jamming up the network). It is used to prevent these loops.
    What is the default gateway?The default gateway is your router's IP address. The default gateway information is not required, but is recommended.What is the default user name and password to log into this device?
    Log in name is "admin" and password is "admin" by default.
    What is WDS Mode?Stands for Wireless Distribution System. Allows access points to link together and provide repeating. Note however, this repeating comes at a cost of reduced bandwidth. Bandwidth will be reduced by 30-40%, and it is recommended that NO multiple repeating hops be done for this reason. Which antenna connector is the primary antenna?The one closer to the power jack.
    Jan 06, 2011 | EnGenius Technologies ECB3500 802.11g High...
    Audio keeps reverting to "cinema" mode even after repeatedly trying to set it on "standard" setting.
    try unplugging unit for several hours ( overnight) this is a hard reset, then when its repluged it should revert to standard mode.
    thanks for using fixya
    Nov 25, 2009 | LG 42LC2D 42 in. LCD HDTV
    Clear all the pre-set channels
    There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
    Mar 16, 2009 | Aiwa Audio Players & Recorders
    How do I adjust date of my watch bought from GAP
    I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
    Nov 12, 2008 | Watches
    Errors list : 46, 50, A1
    CP315C/310CN/120C/115C/117C/110C
    (1) Press the (1) Press the
    Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
    enter the maintenance mode. enter the maintenance mode.
    (2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
    Set keys.* Set keys .*
    (*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
    display the numerical code to be entered and then press the display the numerical code to be entered and then press the
    Set key. Set key. Repeat this operation for each Repeat this operation for each
    numerical code.) numerical code.)
    (3) Press the (3) Press the
    Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
    (4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
    Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
    (5) Press the (5) Press the
    Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
    (6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
    Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
    Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
    EnGenius Technologies ECB3500 802.11g High Power 600mw Access Point/client Bridge/repeater/router/wd Logo
    787 people viewed this question
    Top EnGenius Computers & Internet Experts
    rdarell
    Level 1 Expert
    Karen Gibson
    Level 1 Expert
    Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
