Question about Frigidaire Washing Machines
No spin cycle
Initially, the spin cycle was very loud. Now the machine doesn't go into the spin cycle at all
  • DrDebHF Jun 14, 2008
    Frigidaire model number FWTB69RGS0
  • eric bosman
    eric bosman May 11, 2010
    ?model number
  • 487 Answers
Ok this is normally not to hard to find out what is wrong.
The sound makes me believe it is the motor. ( can be drum bearing but that I dont think) Unless your belt came off. Please check this first before considering a new motor.
HERE you find drawing and all the parts you need.
Good luck
Posted on Jun 14, 2008
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Loudness
If the noise is just at spin cycle the most likely fault is the bearings,not a simple repair but need more inf. thanks tk
Mar 10, 2014 | Maytag Washing Machines
Why is my washer clicking?
does it spin if you let it run?
Sounds to me like a bad transmission..
do you also have model number
Jun 13, 2013 | Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
