Question about Maytag Washing Machines
Only the spin cycle works, please advise - Maytag Washing Machines
Have you checked to see if the pump is working? If not it could be the pump or the programmer board. Can you give more info on the make and model please.
Posted on Nov 05, 2010
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Mar 01, 2018 | Maytag Neptune MAH5500B Front Load Washer
Rinse problem
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Jul 01, 2009 | Kenmore 22642 Top Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Spin cycle does'nt work.
you have a bad basket drive on the washer and with a coldspot the problem will most likely be your defrost timer
Nov 22, 2008 | Kenmore 24032\24036 Top Load Washer
Bendix WD1043 model RV washer/dryer --all cycles work except for the spin-out cycle, starts to spin but then stops and just sits there....the belt is OK, I looked.please advise further....thanks, Jack
KENMORE RV WASHING MACHINE WATER LEVEL DID NOT STOP. IT JUST KEPT GOING & OVERFLOWED. DOES THIS MEAN THE ELECTRONICS NEED REPLACING OR THE ENTIRE MACHINE.
Aug 15, 2008 | Washing Machines
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
