Question about Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black
The Jet Clean System that comes with this razor is malfunctioning. If the cleaning solution reservoir is under-filled the Jet Clean System will flash its lights at you and refuse to operate. This is what happens every time I try to use it, no matter how much or how little cleaning solution I use. I figure that the problem must be with the sensor (blocked? stuck float?) But I cannot find the sensor anywhere. Any ideas?
    Problem Solver:
  • 9 Answers
I have had 3 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Posted on Jan 23, 2011
How do i clean my with my philips hq2000. instructions are in a different langue
  • 1 Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
  • 2 Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
  • 3 Plug the power cord of the cleaning base into and electrical outlet.
  • 4 Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
  • 5 Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
  • 6 Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
  • 7 Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
  • If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
  • Jul 22, 2014 | Philips Norelco Hq200 Jet Clean Solution 2...
    Jet clean system doesn't work
    Did your Jet Clean System used to work, but now rejects the razor and flashes a red indicator that your reservoir is empty when it is not?
    The reason is that the liquid level sensor is full of gunk (you don't want to know what the gunk is made of). You can easily clean this yourself and restore normal operation. Here's how:
    1. Remove the razor and reservoir. Leave it plugged in.
    2. Press the start button and when the holder hits the bottom and stops, immediately pull the plug before it comes back up.
    3. Turn the unit over and clean off the gunk you can see with a Q-Tip.
    4. Fill the cleaned reservoir beyond the line (almost to the top) with hottest tap water and place it on a towel on your counter.
    5. Mix in 1/8 teaspoon of dishwasher detergent. Do not use Dawn or other dish detergent. It must be the type you use in your dishwasher! (Trust me on this).
    6. Lower the unit onto the reservoir and let it soak for at least 20 minutes.
    7. Hold the reservoir down on the towel by depressing the release buttons and pull and put the cleaning unit in and out of the reservoir 20 or more times to flush out the crud.
    8. Refill the reservoir with clean, hot water and do the pull - push trick again many times. Rinse and refill the reservoir with hot water and do this again 2 more times until the water is clear and there is no debris to be seen in the water.
    9. Remove the reservoir and allow the cleaner to dry thoroughly. Depending on the humidity where you do this, drying can take from several hours to an entire day. A hair dryer on the part you cleaned with the Q-Tip may help, but time will still be needed.
    10. Assemble and try it. It should work like new. If it does not work properly, (mine acted like it was jammed) don't worry, it is likely not completely dry inside. Remove the reservoir and wait for it to completely dry before trying again.
    Have fun!
    Apr 09, 2014 | Norelco Arcitec Electric Shaver with Jet...
    HOW DO YOU CLEAN THE RAZOR
    Good day!!!
    if you wish or need to clean you razor you only have to do is to open the cover (unscrew) then use a paint brush to clean the your razor after that put some oil to lubricate the razor and that's it..
    thanks for using fixya..
    have a nice day!!!
    Jun 30, 2011 | Philips Philishave Cool Skin HQ5620
    Lost directions on how to use jet clean system. Do not know how to use it.
    Visit this site below and enter your product number. If you don't have your product number or it doesn't appear, then type in "jet clean" then scroll down and click on personal care. You can then click on a jet clean model and then open the .pdf of the manual. The instructions should be similar. There is nothing to using it. Fill the reservoir with jet clean solution to the max line. Put the shaver in the cradle heads down and press the button on the front of the cleaning base. If it doesn't stay down and clean you may have another problem. If so, then search "Norelco Arcitec Electric Shaver with Jet Clean" on this site and you can find answers to your problems.
    http://www.support.philips.com/support/sms_page.jsp?userLanguage=en&userCountry=us
    Jun 09, 2010 | Norelco Arcitec Electric Shaver with Jet...
    Dirty razor heads
    can of compressed air that you use on your computer and electronics
    Apr 01, 2010 | Norelco Arcitec Electric Shaver with Jet...
    Norelco/Philips jet clean shaver cleaning bath no longer works
    I have had three 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
    Sep 22, 2009 | Philips Norelco 8175XL Electric Shaver
    Norelco Electric Razor problem: Jet Clean System won't work
    You need to fill the based to the max solution line. There is not enough solution in the container.
    Jun 05, 2009 | Norelco Arcitec Electric Shaver with Jet...
    Dawn in the Jet Dry Dispenser
    It may not hurt the machine, but it leaves soap on the clean dishes. You can't really remove the reservoir without dismantling the entire door. it's pretty straightforward, but takes a little time and effort. If you're not prepared to dismantle the door to get to the reservoir, you -could- try cleaning/rinsing it out with a turkey baster and a small diameter piece of plastic tubing. Just suck everything out, then fill it with rinse water and suck that out as well. But you'd have to fill it with rinse water over a dozen times to really get it clean. Hope that helps. ;)
    Aug 09, 2007 | GE 24 in. GSD5560GSS Built-In Dishwasher
    Norelco Arcitec Electric Shaver with Jet Clean System - Gray/Black Logo
    371 people viewed this question
    Top Norelco Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Andrew Taylor
    Andrew Taylor
    Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
