Question about Pentax Optio S50 Digital Camera
4gb Memory card error
When I put in my 4gb memory card into my camera (Pentax optio s50) it reads "Memory card error"
  • 1 more comment
  • Anonymous Jan 03, 2009
    How do you find out if your camera is "SDHC approved" ?
  • euugen Jan 30, 2009
    Help me please with firmware update for Pentax S50 ?!?!
    I have 4Gb sdhc card,  the same problem.
  • thimsel Feb 19, 2009
    I have this same problem with my Pentax optio s4. I get a memory card
    error. I think it may have to do with the memory card contact pins.
    most likely the card was flipped over when inserted and one or more of
    the contact pins was pushed out of place. The expert at the local
    camera shop says that these contact pins require a very sensitive
    adjustment. I have had the camera apart but access to the pins is
    almost impossible. If this is the case, then the sad truth is that to
    have an expert repair this would cost more than the camera is worth.
    One other possibility may be that the firmware needs to be updated to
    restore operation although the internal memory works just fine. Any
  • 2,794 Answers
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
Posted on Jun 14, 2008
How do I cure memory card error even though the card isnt locked?
The S50 works with SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 16, 2012 | Pentax Optio S50 Digital Camera
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
My camera says "memory card error" I have tried to replace the card but still getting the same error message. Any thoughts.... thx
You need to format the card in the camera. This will erase it so download any pics first using a card reader if necessary.
Feb 19, 2010 | Pentax Optio S50 Digital Camera
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Jan 02, 2010 | Pentax Optio S5i Digital Camera
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sep 12, 2009 | Pentax Optio MX4 Digital Camera
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
Optio 430 RS
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
Pentax Optio 60
Largest card for the Optio 60 is 2GB. The camera is not able to take 4GB and larger SDHC type cards. If I answered the question to your satisfaction, don't forget to rate it. Thanks
Feb 26, 2009 | Pentax Optio 60 Digital Camera
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 10, 2008 | Pentax Optio E10 Digital Camera
Pentax Optio S50 Digital Camera Logo
714 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
