Question about Maytag Washing Machines
Water will not shut off, will not agitate. - Maytag Washing Machines
  • 413 Answers
Water pressure switch may have failed OR the water pressure switch hose has a blockage at the air dome.
On the bottom left rear or right rear of the outer plastic tub where the clear hose is connected, is the air dome. Inspect for brown discoloration. Brown discoloration is an indication of a sludge buildup blockage.
Posted on Jun 14, 2008
Washer keeps fling with water and will not agitates it will drain and spin
There is usually a small hose from the outer tub to the water level switch. This ia actually a pressure hose to make the water shut off. If a hole is rubbed into it, you loose the pressure and the washer fill will never shut off. That pressure is needed to switch machine from fill to agitate once it reaches the proper fill level.
Apr 07, 2016 | GE Washing Machines
I have a MTW5620TQ1, The other night I turned it on to fill with water & the power shut off, it flipped a Circuit breaker. Now when it is turned on it will not fill with any water, hot or cold. & when the...
Sounds like a bad water pump, and or bad agitator motor if the washer will not spin. Breaker probably tripped due to one of the 2 drawing too much current.
Aug 23, 2013 | Sears Parts Direct Agitator - 8578210
Washer overfills water does not shut off.
All you gotta do is see if the pressure hose is secure and tight on the pressure switch and the tub ain't clogged with sediment. themobilian_666.jpgthemobilian_667.jpg
Jan 03, 2011 | Washing Machines
Does not agitate and shuts off between cycles
Did you you have this problem after the pump was replace?
If so.. Call your service guy back,. If it was two or three days later different story, different problem!
But it does sound like a timer, or the main computer if it is electronically powered
Jul 24, 2010 | Maytag Washing Machines
The water will not shut off
If the water will not shut off, the problem is most likely a faulty water level switch. The switch is a diaphragm like device that has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As water level rises it, pressure increases on the air in the tube and when it reaches a certain point it activates the switch to shut off the water and signals the timer to begin the agitate cycle. Look for any obstructions in the tube and the switch can be checked with an ohm meter or multimeter for continuity. If the switch has none it is defective and will have to be replaced. Sure hope this helped and best wishes.
Jul 30, 2009 | Whirlpool LCE4332P Top Load Washer
Washer only fills part way before agitation begins
The water level switch regulates your washer's fill volume. The switch is usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises the pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to shut off the water, and signals the timer to start the agitate cycle. If the switch is defective it may prematurely signal the water to shut off. If so, you will probably need to replace the switch. Hope this helped.
Jul 18, 2009 | Washing Machines
My washer is just running water and not filling up
Check water valve may not be shutting off.
Check water level switch should shut water off when full and starts agitate.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 70 series
sound like you need to replace the water valve
Dec 05, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
