Question about Car Audio & Video
JBL Marine MR-4
Cannot get the unit to operate. Screen says "TEL". CD won't play, stereo doesn't work. Just says "TEL".
  • 2 more comments
  • Lbrousseau Jul 09, 2008
    I have an MR-4 that has the same problem. The power comes on but the display just says "tel". I've done a hard reset and the same thing happens. Any suggestions?
  • conductorguy Nov 14, 2008
    Same problem..."tel" appears and no sound. Will accept a CD, but not play.
  • jstrieker Feb 16, 2009
    I have this model on our spa. I just installed but the provider did not give to me an owner's manual. How do you complete the 'hard reset' mentioned previously? I have NO POWER showing at all.
  • eweigeltjr Jun 22, 2014
    any solution to the tel
Hi I have a spa with the MR4 sterio and i want to remove it can you help as i am unable to remove it , the front comes of and i can not see how the rest comes out .
Posted on Apr 03, 2011
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
Volume dial decreases volume if turned either way
i took my head unit face apart and got the volume control off, sprayed a little WD40 and it worked like a beauty!
Jun 03, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Car Audio & Video Logo
538 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
