Question about Microwave Ovens
Our De Dietrich Microwave oven is not working for the past 1 week. Power supply is good, All timer control and other controls and working. When I adjust the settings and press the "start" button nothing happens. It is too costly to get it repaired. Please suggest a solution to solve this problem.
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Microwave stopped working
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Posted on Sep 15, 2007
MicrowaveSvc
  • 9149 Answers
SOURCE: Microwave oven start button not functioning
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 01, 2007
SOURCE: Leak from a De Dietrich
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Posted on Feb 09, 2009
  • 16 Answers
SOURCE: Microwave not working-Sharp 798 M,oven Grill ok
usually the power diode failed if not check the magnetron some time door switch you have to check most of the microwave not worth to hire some one fixed it.if you call some of repair company they will charge mag + cap+diode+ labor it 's total $500.if you don't want to fix you still have to pay for service call $72..you can buy the kitchen counter around $100
Posted on Jun 22, 2009
Our De Dietrich DME715X microwave oven is sparking from the ceiling - have tried a new wave guide cover but that did not work.
Some ovens have a tuning stub in the wave guide. If it has become loose or rusted, it could cause the problem. If that's the cause, you would have to transfer all of the oven's components to a new cavity. This is usually not done due to the cost, although I did do this once on an oven that was still under warranty.
Make sure the wave guide is clean inside.
Also check for rust near the wave guide cover. Re painting damaged areas might help.
Sparks fly, too, if the ovens contents do not contain enough water to absorb enough of the microwave energy. Leftover energy converts itself into electrical current in any conductive material (such as cavity panels).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 25, 2016 | De Dietrich Microwave Ovens
Microwave "popped" during use
Could be an open internal fuse
Sep 07, 2016 | De Dietrich Microwave Ovens
How to reset De Dietrich oven DO410
follow this step and fix it. A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
God bless you
Jul 20, 2013 | De Dietrich Microwave Ovens
I have DME321XE16 De Dietrich microwave. I have a problem as for the past week I have been able to smell a burning plastic smell coming from the control panel when microwaving something. I have checked as...
i would recommend not to operate it in this situation & should be opened and investigate the cause of the smell, most likely it'll be a very hot component on the board or a freaky contacts.
Oct 29, 2017 | Microwave Ovens
Tried to change time on clock and all the power has gone out of the microwave
The fuse in the microwave has blown, there are any number of reasons for this, one of the door switches has failed, "common problem" or in some cases just the fuse will go.
Mar 25, 2012 | De Dietrich DME101 1000 Watts Convection /...
The turn table doesn't always rotate. If you move it manually it will sometimes work for a short while.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 04, 2011 | De Dietrich MM6768 900 Watts Convection /...
Start button doesn't work for all microwave functions--as well as timer--fuse is ok
Possible causes:
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Dec 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has power but start button not working
Usually a shorted high voltage capacitor...see components section
Sep 17, 2009 | De Dietrich DME112X Microwave Oven
Model# DME315XE14 (17 months old). Control panel is not displaying properly so although the microwave is working, I am unable to set the clock or display the length of time or the wattage. Hope you can...
The control panel can be repaired or replaced, depending on the quality level of the technician or engineer doing the work.
You can contact DeDietrich here to find an authorized repair center in the UK.
Aug 04, 2008 | De Dietrich Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
