Question about Samsung Washing Machines
Clicking noise in spin cycle, this is a front loading VRT washer. Seems to come from front of machine.
  • 3 more comments
  • hamelin7 Nov 05, 2010
    Checked and found nothing.
    The clicking starts not in the beginning of the spin cycle but when it starts to go into high speed and continues through the high speed spin.
    Can this be replace easily and is it normal for this to happen in a machine 1-1/2 years old ?
    How much should this cost and what if I wait till it gets worse?
    Thanks!
  • hamelin7 Nov 06, 2010
    Not sure if this is the problem or not but thanks for the help
  • 2,382 Answers
Hi, open the door and with your hand (glove on if preferred), feel around the interior of the drum for perhaps nails, bra wire, hair clip or something in the spin basket holes or in the pump....
Posted on Nov 05, 2010
  • 2 more comments
  • Tunde Autos
    Tunde Autos Nov 05, 2010
    Hi, then it has to do with the drum bearing wearing out. Check out the drum bearing...
  • Tunde Autos
    With the quality of what is been produced nowadays, it is possible to happen in a six month machine.
    You require the service of a repair man to replace it...
  • Tunde Autos
    It shouldn't cost more than $70 i guess depending on the repairman. I advise you stop using it ir else you end up damaging the drum..
  • Tunde Autos
    You can now accept and rate the solution...
I have a samsung VRT steam washer, front load. When in the spin cycle, it makes a very loud noise..like the drum is going to come flying out at any time..scary..any suggestions ?
I have a Maytag Neptune front load washer. I had a similar problem, had to replace the bearings for the drum. It sounded like a jet engine spooling up until I replaced the bearings. I watched a video on how to replace them on Youtube.
Jul 08, 2018 | Samsung Washing Machines
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Samsung front loader smokes
Please do not run machine with smoke coming from washer. You could create a fire. Unplug power cord, and call a qualified service person.
May 12, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Wash shakes on the spend cycle
I would check to make sure the washer is level, the drum sounds like it's not spinning evenly and if the load isn't unbalanced it might just not be level front to back and side to side.
Mar 01, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Samsung washer -front load -noise wobble
Sounds a lot like a bad rear bearing. I replace them all the time
Feb 19, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
Aug 22, 2012 | Samsung WF231ANW 3.5 cu. ft. High...
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Washing Machines Logo
264 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
