I have a Gateway notebook that is just over a year old. The computer went off and will not come back on. I contacted Gateway and they told me to remove the battery and harddrive, replace harddrive then wait 30 min replace battery and it should come on, it still won't power on. Contacted Gateway again and they told me to sent in for repairs, no other suggestions. Any ideas what it maight be? I am not returning to Gateway because I need the computer repaired asap as I use for work. Thanks
im doing catch up on gateway posts. just 1 day here.
Gateway 2000 Vivitron 17
omg a CRT really?
Gateway2000 Vivitron CRT Monitor 17" CPD-GF200
only google finds manuals on Monitors 2 decades old
nobody fixes CRTs now, and are dangerous with 17,000 volts inside
that can linger. ok>?
time to upgrade no? buy a used LCD LED 2010 or newer flat screen monitor and forget you saw, WAR GAMES and WOPPER
Sorry to say but we're not connected with gateway and not sure why you're redirected here to us, but if you want to talk to a gateway tech on phone you can contact them on this number 1-800-846-2000.
Frequently Asked Questions Q: How do I turn my notebook's wireless on and off?
A: Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide.
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation.
User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from our Notebook User Guides support page. http://support.gateway.com/support/manlib/Notebooks/notebook.shtml
Another source of reference for networking your computer is the Gateway Notebook Networking Guide. http://support.gateway.com/s/Mobile/Gateway/M250/8510650.pdf
Quick reference:
Gateway® M675 - Multi-function button (last on right)
Gateway® 200ARC - Multi-function button (last on right)
Gateway® M505 - Multi-function button (first on top)
Gateway® M500 - Multi-function button (first on top)
The Gateway® M275 notebook uses the system keys FN+F7
User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page.
Quick reference:
You can restore the computer back to factory default,to do so, follow the below steps: Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
If the above mentioned steps are not working then you need an RCD to do so. Contact the Gateway support.
hi there, it may be that your cable connecting your monitor to the computer is being wiggled loose. You need to leave this to the pros as this can't be explained over the internet. You need to bring it to a computer shop for them to reconnect the computer. Tell them that the monitor cable is being severed from the graphics card.
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
