Question about Yamaha CDC-655 CD Player
CDC-655 was put in storage (in orig box) and brought back out and plugged in. It loads each CD and fails to read each one. The lighted numbers go out, one by one, as it fails to read them.
    Novelist:
  • 77 Answers
This seems to be a "Dust on Lens" problem. No issues... It happens when you keep your CD/DVD players unattended for a long period of time. Even if packed well enough, dust/moisture does tend to gather on the lens and cause this type of an irritating problem.
If you have a lens cleaning CD (if not, go buy one) then just insert it and let it spin regardless of whether or not it reads it. The spinning action will clean off any finely deposited dust particles on the lens. Repeat th process till the Lens Cleaner CD starts playing its audio. If this happens then all your other CDs should read. One more thing, make sure that the motor is indeed spinning. How can you know???
1. Buy listening carefully for a whirring sound the moment you put in your CD/DVD
2. By feeling for minor vibrations on the front panel (CD tray front cover)
3. Putting in a CD/DVD with a label straight as you can read it and see if it comes out differently on ejecting it. I hope you understand what I mean...
If this doesn't then it could be a blown lens circuit or a dead drive motor. In that case your player needs to be taken to a service center.
Hope it answers most of your query. Good luck.
Posted on Nov 05, 2010
My CDC-655 works beautifully, but suddenly has stopped responding to the "Random" button on the remote. It will play tracks on the currently-playing CD randomly, but does not go randomly from one dis
CLEAN CONTACTS ON CIRCUIT BOARD BY CLEANING THEN WITH A PENCIL ERASER. SOME TIMES CONTACT SOLUTION ON BOTTOM OF THE BUTTON WEARS OFF. I BEEN NOTED TO USE NICKLE PRINT ON BOTTOM OF THE RUBBER BUTTON TO REPAIR WARN CONTACTS . PLEASE MAKE SURE NICKLE PRINT COMPLETELY DRY BEFORE PUTTING REMOTE BACK TOGETHER.
Nov 29, 2014 | Yamaha CDC-655 CD Player
Pwr. on but won't play cd,
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Nov 01, 2012 | Yamaha CDC-655 CD Player
Fuse inside of player might of blowin,Cover has to ge taken off,To replace it,
Yamaha CDC-80 drawer won't open
Hello
There are two possiblities for this fault. The first one is, loading belt broken, or loose. The second one is, loading motor fails to rotate. it may be due to voltage related problem, that is, no voltage comes to it from the circuit board, or it has failed to rotate due to some internal fault itself.
You just open and inspect for these troubles Ok.
Nov 27, 2010 | Yamaha CDC-655 CD Player
Player will not read cd . Cd will not spin
Without me seeing it, it usually cannot read the disc and is caused by a defective, or needs to be adjusted or cleaned, laser assembly as long as it is every cd put in it. It can also be the disc spinner motor. Either one of those is the most likely cause. :)
May 19, 2010 | Yamaha CDC-845 5-Disc CD Changer
It does not read the CD, as if the reader does not recognize it
is the files on the CD the right kind of file that the player reads? you might wanna check that
Mar 21, 2010 | Yamaha CDC-655 CD Player
Yamaha CDC-655 CD Player Logo
178 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
