Question about Motorola Mobility RAZR V3
SAVING BATTERY LIFE ON Motorolas Or Anyphone
Ok Heres A Trick Go To SETTINGS on Ur Phone. Then Find Initial Setup. Then Change Ur Backlight To 20 Secs Then Find BRIGHTNESS and Turn That Down All The Way Down N That Will Save U At Least An Hour Or 2 Of Battery Life. Mine Lasts A Whole Day And The Next Morning Till About 10 Then I Have To Put It On The Charger.
    Brigadier General:
  • 7,752 Answers
Great thks for the tip
Posted on Jun 25, 2008
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
Tip
How to increase battery life in LG GT505
Feeling tired that after surfing the web or playing a few games, the battery is halfway through to being dead?
So this Tip is for you!
What we're going to do, is put every setting on the minimum so that it doesn't waste battery life that much when you're just typing a SMS.
1 - Open the Menu and click on the last icon (on the right bar) on the bottom. - Settings
2-Open Phone Settings, and slide the Power Save button to turn it ON.
3- Now go back to Settings and go to Screen Settings and choose Brightness. Set it to 0% and Save it (click Yes even if it tells you that you are changing the Power Save Settings)
4 - (Optional) If you don't mind your phone turning off the backlight real quick, you can change the amount of time it stays on, but if you send or read a lot of messages, it can become a bit annoying, so it's really up to you! Anyway, in Settings, choose Screen Settings, then Backlight, and choose whatever time suits you. Keep in mind, that the lower the time stays on, the more it saves up battery life.
Imagine you just made a phone call, then put the phone on your pocket. For some time, it's backlight is on for a long time, maximum brightness and you're not even looking at the phone. That's a waste of battery power!
Using those new settings, you can get up to 3 days battery while playing a fair amount of games!
on May 16, 2010 | LG GT505 Cell Phone
Mobile habg
Try this under Settings Menu:
Initial Setup
• SpeakerPhone
• Auto Redial
• Display Timeout
• Backlight
• TTY Setup
• Scroll
• Language
• Battery Save
• Brightness
• DTMF
• Hyphenation
Master Reset
Master Clear
And as far as the Reset Code try (666666) it worked on an older MOTO. phone. Hope this helps
May 08, 2010 | Motorola Mobility SLVR L7 Cellular Phone
I cannot change my Motorola L6i back to English.
1)Go to menu/setting/initial setup/language/chose English press ok.or
2)Menu/setting select/navigation key down 5 times/initial setup press change/pess navi key down 5 times,press change,then select English press change.hope to solve problem.
Aug 16, 2009 | Motorola Mobility L6 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Changing the time on my Motorola Razr V3 phone
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
My Tracfones screen will not turn on. I have taken out the batteries and put them back in, it was fully charged and I have over 600 minutes. Should I reset it, and how do you reset it?
According to the manual they suggest that the Backlight may be set to "OFF". To change this press the Menu key>Settings>Other Settings>Initial Setup>Backlight, and change it to on. If this doesn't work and you suspect that the display is truly burnt out, Go to your nearest mega store and buy a C139 tracfone for $14 and switch out your SIM card. your minutes and service should be be transfered to the new phone
Apr 07, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Motorola Razr cell phone
You didn't mention what carrier you have.
For Verizon:
1. Go to "Settings & Tools"
2. Scroll down & select on "Initial Setup"
You will see a setting called "Backlight". You will be able to set it 5, 10 and 20 seconds.
Good Luck!
- Jim
Jan 26, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Clock
Its on page 52 of the manual, click on the model number above. Scroll down till you see the manual Heres what it says Shortcut: Press M# from the home screen Find the Feature M>Settings >Initial Setup > Time Good Luck
Oct 29, 2006 | Motorola Mobility V300
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
