Question about Samsung Propel A767 Cell Phone
I've had my propel for almost a year and a half. It was working fine until recently the display wouldn't come up when the phone was closed, now it won't come up when the phone is open either so I have no display at all.
    Sergeant:
  • 415 Answers
The samsung propel has been known to do this and other things after being used for anywhere from 6mos-to-2yrs. It will begin to turn itself off and on and call people and skip your lock code and send texts and the letters will jumble. I suggest you trade it in for a completely different phone before it really crashes and fries your simcard.
Posted on Nov 07, 2010
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Check engine light car shaking
Failed ignition coil most likely.
Other causes...sparkplugs, HT leads.
Jun 23, 2013 | Mini Cars & Trucks
I recently purchased a Sears 22 self propelled with rear bag
they only catch grass not dirt they need air flow to work and if not porous they wouldn't work
May 31, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
My 1999 Toyota 4 Runner wouldn't start recently
You either have a defective battery or the battery cable or cables have acid intrusion that has "wicked" inside the cable and this causes a bad connection, the only fix is to replace the cable or cables, this problem is mostly limited to the positive battery cable because of the current flow direction. So 1st have the battery tested and see what it shows, almost any of the many discount auto parts stores will test the battery for free.
Jan 20, 2012 | 1999 Toyota 4Runner
Oil Leak from briggs and stratton m ower engine. Mower just a year old. Used very little. was fine last week,
I wouldn,t say that your lower seal is bad. I will ask you if you've changed your oil, and maybe not tightened the plug. Now it is possible that you haven't changed your oil and for some reason your oil plug has loosened enough for your oil loss or completely unscrewed and fallen out. In either case tighen if there, or replace with new one if not there fill with oiland see if it's OK. GOOD LUCK.
Sep 26, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a 1995 mercury sable. I've it for 5 years with no transmission problems until June, 2011. I've noticed that when I drive short distances, the car drives great but if I do 12 miles on the...
The average life of a taurus or sable transaxles is a
surprising 65,000 miles,then you have to rebuild it
I only recently read that
In the early 1990's I owned a trans repair business
& over half my work was taurus & caravans
The rest was japanese
I can not see that being the original transaxle from
1995, but I wouldn't hold out hope of any type of
simple fix
There are non to my recall ,other than a cable on
the throttle body & I don't even know if they still exist
Aug 04, 2011 | 1995 Mercury Sable
When phone is turned on it gives download message on screen
I've had the propel for a year an a half an really like it.today i experienced the "download" screen an spent nearly 2 hours with tech support. they concluded the phone was "probably spent" so i ordered a new model (free of course). however, due to my unsatiable appetite for self reliance I decided to tinker with the phone one last time. This is the solution that actually friggin worked: all you have to do is repeatedly plug and unplug the charger from the phone until the "download" screen goes away. how often the simple solutions elude us.now i gotta try an cancel my order for the new phone.at least i can do it from my propel, yahoo!!!
Sep 07, 2010 | Samsung Star GT-S5233 Cell Phone
Banging noise when motor turns off
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Feb 05, 2010 | Honeywell Electronic Programmable...
The slide to turn on the phone will not move.
Try using the stylus located bottom right. Use finger nail to flick out. Once you've done this select settings and select pen calibration until Done appears on screen this sets the sensor according to your touch!
All the best.
Aug 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Samsung Propel - Download Message
ok had the same a767 propel for att in white
Drove me crazy that the phone was in download screen mode
So best fix and it is proven :is to open phone and disconnect small battery on mother board of the phone then leave it out for about 2 mins and leave it out
then put it back together all fixed works and powers up just fine :)
Jun 17, 2009 | Samsung Propel A767 Cell Phone
Cannot load my contacts - motorazr v8
This might be late and you may have already solved your problem by now, but in case you haven't, you'll have to flash the pone and reload the software ...
Feb 06, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Samsung Propel A767 Cell Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
