Question about Kenmore 2303x Top Load Washer
Re: Kenmore model 23032 - When washing a load that is on the heavier side (for example 5 bath size towels) the basket does not spin, but the motor runs and the timer works fine. I opened the lid and rotated the basket about 270 degrees, set the timer to spin, and closed the lid, and this time the basket did spin. Load was relatively balanced and I did not change location of the towels oin the basket. There is a slight smell of oil or rubber being heated. What do you think the problem is, and what would it cost for a Sears repairman to come out and repair this problem? Trying to decide to repair or replace.
    President:
  • 1,430 Answers
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. Here is a video this will walk you thru this disassembling and replacing a motor coupler in a direct drive machine. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Cost depends on your area, in upstate NY we charge $60 labor plus a $45 service call charge plus the cost of the part about $125 total.
Posted on Nov 05, 2010
My washing machine tub seems real loose. It starts banging on the sides when starting to spin. What causes that?
Hi Steve, This is usually caused by an uneven load. For instance, If you have a bath towel in with some shirts or tea towels, the bath towel absorbes more water than the tea towels, thus making an uneven load.
My wife tends to wash slippers in a pillow case with nothing else in the washer, and the drum will bang against the side.
Hope this helps
Kind regards
David
Nov 10, 2017 | Washing Machines
Kenmore 23032 top load direct drive washer will not agitate or spin, but still does drain - is this the clutch or drive motor?
no replace coupling # 285753 double shafted drive motor ... coupling attatches motor to transmission look for black rubber and off white plastic chuncks under washer.......
Jan 31, 2011 | Kenmore Washing Machines
Washer is rotating like it is out of balance on all loads. This never occured before unless it was truly out of balance from large heavy loads like bath towels loaded on one side of tub. I dont know what...
You could have a broken spring4addd15.gifor you could have a worn pad or it could just be that the skate plate is out of alignment with the base.a10a515.jpg872a09e.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2010 | Kenmore Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Motor just hums.
I NEED YOU R MODEL NUMBER FOUND AROUND WASHER TUB OPENING SHOULD HAVE NUMBERS AND/OR LETTERS I YIELD NOTHING WITH 23032
Apr 11, 2009 | Kenmore 2303x Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Water does not stop when in spin cycle,# 23032
Check three things. Check your Water inlet valve with a multimeter, check your timer and you water sensor. All can be found behind the knobs by removing two side screws and 4 screws in the back of the unit. If this helped please rate. Thank you
Feb 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 2303x Top Load Washer Logo
204 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
