Question about Craftsman Garden
My craftsman gas edger Model 358.773100 the fuel lines were cut. looking for diagram to repair
  • Roy Cagle
    Roy Cagle Nov 06, 2010
    This model not showing up in the Sears database. Is this a 2 stroke weedeater type machine with the primer bulb for the carburetor? Post back to receive more help.
4 Suggested Answers
  • 53 Answers
SOURCE: replacing fuel tank on craftsman edger and other
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Posted on Jul 20, 2009
rycgl
  • 1545 Answers
SOURCE: gas edger Model 358.773100 the
They don't really have fuel line routing diagrams available. This is even true on the Sears website. What they do have is the machine breakdown diagrams with all the parts listed and pricing for all available parts. I can give you fuel line instructions for a 32cc trimmer. I see that your model is a 24cc 2-stroke engine. This may point you in the right direction.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Nov 28, 2010
  • 19 Answers
SOURCE: got a craftsman convertible 32cc
Try searspartsdirect.com You'll need the model number... plug it in and you should be able to pull up a schematic.
Posted on Oct 31, 2011
Gas edger Model 358.773100 the fuel lines were cut. looking for diagram to repair
Nov 28, 2010 | Craftsman Garden
I have a craftsman gas weekwacker model 356.791520 is there any diagram of the fuel lines. I think I repaired them wrong.
Looks like you've possibly referenced the wrong model # for your trimmer. There is a diagram available for model 358.791520, but not a 356.791520. You can find it here - http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791520/0247/1503820?searchedModel=791520&blt=11.
Once you get the Sears numbers for parts you need, you can find replacements for them at HyperParts.com's cross-referencing page here.
May 19, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel bulb is not bringing in fuel when pushed
The larger line connects to the primer and returns fuel to tank. The smaller line has the fuel filter connected to it in the tank and connects to the small fitting on the side of carb.
Sounds like your problem is in the carb. You need to look your model up in Sears Parts because some models require replacing the entire carb.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
Can't find gas line diagram for craftsman
The drawings arent spectacular, but it's the best we have.
Click HERE.
Hope this helps.
Oct 04, 2009 | Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
May 24, 2009 | Craftsman Gas Mini - Tiller/Edger
Fuel hoses routed wrong on weed eater fuel tank
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
721 people viewed this question
Top Craftsman Garden Experts
Jim Parker
Jim Parker
john h
lnbn1975
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
