Question about Combi Centre DX - Mango
Pressure of Ariston Microporus 27 MFFI
I have an Ariston 27 and I do not know which are the min and maximun pressure in bars that should be working the boiler when the radiators are hot and the bolider is working.
  • Anonymous Mar 28, 2014
    I have an Ariston pro eco 80v 2k boiler and while it's heating the preasure inside gets very high and the valve is leaking.is that something wrong with the boiler or it's only the valve broken?
    Problem Solver:
  • 7 Answers
The boiler reqs to be pressurised to 1 bar in a cold state, in operation the heat expansion with cause the gauge to rise by about half a bar so in full working mode with heating on you'll expext the gauge to register around 1 1/2 bar-
Posted on Sep 18, 2008
Sorry Terry - I'm not used to this site! Question was - anyone know what the error message E34 means on an Ariston Boiler MicroGenus 24HE please?
The information I have found states it is a problem with the pressure switch. A faulty pressure switch will prevent ignition from occurring. Here is a Youtube video link showing the issue. Reading the comments below may assist you in isolating your problem. Hope this helps!
Ariston microGENUS 24 HE MFFI Error 34
Oct 21, 2015 | Washing Machines
No hot water pressure in bathroom
bleed the system,sounds like an airlock issue
Apr 05, 2017 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Ariston microcombi 23 mffi Boiler Manuals
its the air pressure switch. needs replacing. they are quite cheap but it could be something a little more expensive but you wont know until you replace it. easy half hour fix
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
HEATING PROBLEM
have checked the pump is working ,is the pressure right on the boiler is there air in the pump or air in the rads?
May 11, 2010 | Heating & Cooling
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
Moved in house Monday & have a radiator leak due to bad rust...what's best temporary repair to hold for a few weeks b4 plumber available? What sort of Boiler is Ariston Genus 24 mffi ?
turn both valves off at each side of radiator and once the pressure balances it will stop leaking, there is no solution to this whilst using this as a radiator to heat the space, but will stop the leak.
Dec 24, 2008 | Water Heaters
Ariston microgenus 27 pressure on 0
Filling loop is underneath the boiler, easily identified as a chrome coloured braided pipe with a black tap at either end. Open right hand tap first then left hand one . Fill system till presure gauge reads just over 1 bar when system is cold. Then turn both taps off.
Jul 08, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
195 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
