Question about The Learning Company The Print Shop 11 Full Version for PC
I have an antiquated version of Print Shop Deluxe 6. How do I get the text of those brochure files .pdp open in more current programs.
  • 3,083 Answers
The correct answer is "with great difficulty", if at all. Just as some functions of Microsoft Word are not backwards compatible, so it is with current programs. They just aren't necessarily written to accomodate older software.
Wish there was some easy fix to tell you about, and hopefully some tech will have a trick up his sleeve for you. Good luck.
Posted on Nov 05, 2010
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
Will a previous file open on The Print Shop 21 if it is being run on a new 64 bit windows
Yes, especially yes if it's Windows 7. Works well with older programs and 32 bit programs. Hope this info helps ;)
Dec 31, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I can't open sig. files on window 7 keeps saying not supported will not allow me to use the software to open either. no matter that i the print shop as default
Print Shop 20 is not completely compatible with Windows 7. For example, when I try to open a Print Shop 20 project on my Windows 7 computer, by double-clicking on the file which is displaying the Broderbund logo, I receive an error message which says, "There was a problem sending the command to the program." And, even though the Print Shop 20 file will eventually open, it actually opens in PrintMaster.
It is, however, possible to force the file to open in Print Shop 20 by doing this:
1. Open Windows Explorer, then find and right click on a Print Shop 20 *.sig file.
2. When the menu drops down, click on 'Open with...'.
3. When the 'Open with' window opens, make sure that there is a check mark in the box next to 'Always use the selected program to open this kind of file'.
4. If Print Shop 20 is displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on Print Shop 20, then click on OK.
If Print Shop 20 is NOT displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on the 'Browse' button.
5. When the second 'Open With' window opens, navigate to this folder
C:\Program Files (x86)\The Print Shop 20\The Print Shop 20
then, click on the tps.exe file.
6. Then, click on 'Open' then click on 'OK'.
This should cause all *.sig files to automatically open in Print Shop 20 when you double-click on them. However, since file associations are always based on the file extension of the project file, it might be necessary to repeat the process above for all Print Shop 20 file extensions.
Hope this helps....
Nov 17, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Jan 30, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Program won't open
I don't use that program but perhps I can easy your anxiety a little. You won't lose your brochure if you back it up. Without opening the programs you tried to open your brochure in simply go to the file itself that contains your brochure and copy it to a dvd or a portable media storage. Depending on the size of the file you may be able to zip it and email yourself a copy. Now that your work is safe and away from danger you can try to focus on what is freezing your computer. perhaps instead of trying to convert to PDF format you may try the print command. Instead of printing to your printer, select PDF as your printer. When I create a lengthy project, I always save a few copioes on my computer under different names so i have safety nets just in case I mess up. Good Luck
Jan 04, 2010 | Encore The Print Shop 23 Pro Publisher...
Does not read .sig files
Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; in work-related e-mails, the signature may also include the name of the person's company, the person's title, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook
tri.gif Microsoft Outlook Express
Broderbund Sign File Popularity 3.gif Average Category Image Files File Description Image format used for signs and posters created with Broderbund graphics software, such as PrintMaster and The Print Shop; can be opened with the program that created the file and possibly with other Broderbund programs or versions, but compatibility is not guaranteed. Program(s) that open sig files mac.gif Mac OS tri.gif Broderbund The Print Shop
windows.gif Windows tri.gif Broderbund The Print Shop or PrintMaster
Jul 02, 2009 | Broderbund The Print Shop 20 Deluxe for PC
Cannot load JPG files in Print Shop 23
is your programme a text only prog? are u frying to load graphics using a text transfer button? try the insert button instead of the import button then choose picture.
Apr 16, 2009 | Encore The Print Shop 23 Deluxe Full...
The Learning Company The Print Shop 11 Full Version for PC Logo
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
