Motorola GP300 Compatible 2 Way Radio Battery Eliminator
Problem for Motorola GP300 Compatible 2 Way Radio Battery Eliminator
Problems setting up Motorolla GM300
By XeBurnout on Jun 14, 2008
I just got a reconditioned GM300 but I seem to have it set up wrong. The channels seem to be programmed correctly as I can transmit to an HT and receive the signal fine. But when I try to receive on the GM300 I hear nothing. I have tried it with the squelch both on and off. When the squelch is on the tx light flashes. The speaker seems fine since the volume of the static with the squelch off is deafening.
Thank you for any help.
Respectfully,
Phil
Solution #1
posted on Jun 26, 2008
Not Rated)
eradiostore
Rank: Guru  Phones & Accessories  Expert
Rating: 91%, 341 votes
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Was this helpful?
Yes
No
Popular Solutions for Motorola GP300 Compatible 2
Questions and Unsolved Problems for Motorola GP300 Compatible 2
Do you recommend Motorola GP300 Compatible 2 Way Radio Battery Eliminator?
Answer
Answer
Bendix King KX-125 very low Com audio output while NAV is loud
Answer
Hi , we have a Furuno FS1552 HF radio, that our tech tells us we need a U16 IC(intetrated circuit)... (More)
Answer
Hi, I bought a pro tekk uhf two way radio and thought I could use it with another uhf radio of a... (More)
Answer
Ref:FT-840 Everytime on turn the power on,the DISPLAY starts to flash,cant go any further???... (More)
Answer
Can anyone be so kind as to email me a PDF service/repair manual for a MOTOROLA CP110 Radio?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top 2 Way Radio Experts
Top Telephone Repairmen
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
