Question about Lexmark X3470 All-In-One InkJet Printer
Computer wont start
Hi, i have windows Vista and my computer wont boot up with my x3470 plugged in. As soon as i un plug the USB, it fires up straight away
  • kingy38 Jun 14, 2008
    yes, i have tried different cables. I cant work out why the computer wont boot, with the usb lead in
  • Lexmark Master
  • 2,794 Answers
Do you have a replacement USB cable?
Posted on Jun 14, 2008
  • Tim Babcock
    Tim Babcock Jun 14, 2008
    This could be a solution.
    Go into you BIOS setting and make sure it isn't looking for USB devices to boot the computer up with. If it does, change the order to third priority.
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Dell latitue D610 stuck on black screen with a blinking cursore.. help?
First, try and boot into safe mode by powering off your computer then powering it back on and tapping the f8 key, after that you should see safe mode and other options below it, click the first option which is safe mode, then go into your start menu and go to your system restore which in Windows 7 and Vista is located in accessories and then system tools, then choose a restore point earlier than the date you are on. This is a temporary fix and you will need to get a virus removal done asap. Hope this helps.
Live Technical Support
My Youtube Channel
Mar 24, 2013 | Dell Latitude D610 Notebook
Tryng to instal the printer driver for a Lexmark 3470 to a Windows Vista desktop.
Use the link below the download and install the Lexmark X3470 printer driver for Vista on your computer: - Lexmark X3470 Printer Driver for Vista 32-bit - Lexmark X3470 Printer Driver for Vista 64-bit
Follow the instructions on your computer screen.
Sep 21, 2011 | Lexmark X3470 All-In-One InkJet Printer
Hi I posted a problem last night about my asus eee pc 1005ha... kept rebooting at windows load screen. so I brought a dvd burner to run windows disk & do repar. it would go through everything fine...
Hi.
Solving your problem is just as easy as 2 hour work. not more..
By the time you were having the restarting problems.. all you had to do was to boot from usb cd-rom using Hirenes boot cd 10.
It starts a small intergrated windows. then you would have to go to a menu to stop some un-named startup bugs that cause the restart when Explorer.exe is being executed by windows.
so now, if you have your backups safe, get instruction on the internet on how to make a bootable usb windows vista or 7 Setup. windows seven comes with many drivers for new laptops.
Boot your computer from USB flash disk, run the windows 7 setup and enjoy..
hope this information helps you because it helped me with Acer One netbook..
good luck
Nov 23, 2010 | Computers & Internet
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Bought a new computer and cannot download the printer because the disc is scratched. can i do this online
What is the exact model number of your printer (e.g. Lexmark X3470, Lexmark X6675, etc)? What is the operating system of your computer? If Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by clicking on Windows logo Start menu > right click on Computer > Properties. With these information, I should be able to point you straight to the driver and see if it's compatible with your computer's operating system.
Apr 15, 2010 | Lexmark X3470 All-In-One InkJet Printer
Computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store but as soon as I plugged it in at home office it didn't turn off
Unplug any external devices: Printer, hard drive, usb drive, network cord or anything that was not plugged in at the shop and see if it starts up. Once you are on a Desktop, plug them in one at a time. If you are using USB devices, try and use the back Ports instead of the front USB ports due to some machines having issues with it on start up with XP and Vista.
If all else fails, press F8 before Windows starts up and boot into safe mode. If it successfully boots into safe mode, you have a corrupt driver and you will need to make sure you have all your drivers up to date.
Dec 14, 2009 | Computers & Internet
When i start my pc acer aspire m1641 after microsift corporation
go into the bios and make sure the USB controller are enabled, save settings and reboot if still same drivers are missing from the operating system, if you haven't got a password boot to windows and plug the keyboard in a different port to re-install the drivers. if you can't, does the computer support ordinary keyboards?
Nov 21, 2008 | Acer Aspire M1641-U1521A PC Desktop
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
