Question about DXG Technology DXG-506V DV Digital Camcorder
Image Fades We have a good image when it is first turned on. However, the image fades before you can take a picture. This occurs only for the picture. The video feature stays focused and clear. It is not the battery. Please help.
  • 2,794 Answers
If you have an tripod that could fix the problem.
The camera could be detecting movement and it doesn't have the movement sensor turned on or it doesn't have one at all.
You might want to check the manual and see.
Posted on Jun 14, 2008
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
My Sony Cybershot DSC V1 viewfinder screen very briefly shows the taken image and this then quickly fades to a foggy whiteout which sometimes shows the ghost of the image taken. The same image shows when...
It is possible that the image sensor which is the CCD- charge coupled device is faulty and will need a replacement. However it is important that the OE part is required and so is best to take consensus with Sony spares and service.
Mar 14, 2012 | Sony Cyber-Shot DSC-V1 Digital Camera
DLP rear projection tv picture fades after a while, image flikers
Good day!!!!
That problem is usually cause of bad light engine..Try to replace it with the same part #..
Jan 07, 2012 | Toshiba 62HM95 62" DLP HDTV
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Quality starts out good, and then fades quickly
You probably running out of black ink. Try replacing with new black ink cartridge.
Try to run a test print.
Jul 18, 2009 | Office Equipment & Supplies
Acer lcd monitorX221W : 18 months old, no prior problems. Today, image suddenly went out. Upon restarting, the name ACER comes on , fades after a few seconds, then the prompt to fill in Password. The...
Sounds a lot like the backlight for it is just about dead. Nothing you've done can cause this to happen, and it certainly isn't a setting on the monitor or PC.
The backlight can be bought as a part, and replaced by a technician (or yourself if you have a rough idea what you're doing). By the time you find one, buy it, ship it, fit it... it might not be worth your time for the cost of a new 21" widescreen monitor.
You'd probably recoup some loss by selling it as faulty for parts too.
Still, be 100% sure before you do it... borrow a monitor and plug it in. I bet the borrowed monitor won't behave the same way. =-]
Aug 20, 2008 | Computers & Internet
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Jpeg image spreads/fades in internet web page
not quite sure what you mean about spreading and fading, but make sure you have the latest version of Java installed and that your internet settings are not set too high as it may dissable some pictures on the net. http://www.java.com/en/download/index.jsp
Jun 24, 2007 | Toshiba Satellite M100 Notebook
32" Trinitron warms up picture goes black
You need to call for service now that the unit still turns on,the problem will become expensive if you try to use it like this,right now the set might have loose conections in the power supply,horizontal driver transformer.ETC.Be safe and call a service tech.
Sep 25, 2006 | RCA P46924 46" Rear Projection Television
DXG Technology DXG-506V DV Digital Camcorder Logo
Top DXG Technology Video Cameras Experts
Jose Ma DM.
Jose Ma DM.
SHARCNET-USA
SHARCNET-USA
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
