Question about Hitachi 50V710 50" Rear Projection HDTV-Ready Television
How to connect wireless headphones
Is there a way to connect wireless headphones to my Hitachi 50V710 tv? I have a set of RCA headphones with only a headphone jack.
I have a Y Cable (quarter inch stereo to dual phono plug) that works with my other TVs.
Don't know which jack to plug into on Hitachi.
  • 183 Answers
SOURCE: headphone socket won't work
Dear Customer,
Try this to solve your problem,
you have to check your headset in other system that your headset properly work or not .THIS WAY YOU CAN FIND YOUR HEADSET OR ITS PIN DAMAGE OR NOT.
than you can attach another speaker or another headset to your lcd output ,THIS WAY YOU CAN FIND YOUR PINOUT IS WORKING OR NOT .
than you have to realize that your lcd is not importing cause some models are design for proper country for porper signal identification code,so YOUR LCD MUST NOT IMPORT FROM ANOTHER COUNTRY,
check your volume level of your headset or amplifier,THIS WAY YOU MAY BE GOT YOUR SOUND IF ABOVE ALL ARE SUCCEDED.
you can check your power plug for your amplifier & volume settings also,
approximate 1200 pounds you had spent on this LCD ,
& at last i must have to tell you that before you many customer have same problem with sounds & video also so its failure model in hitachi if you have any warrenty than than replace or try to buy inplace of this model like panasonic LCD's are best,
or you can use your customer number for given with your documents buy on lcd to replace or any damage,USING THIS YOU CAN GET YOUR NEW SOUNDS FROM YOUR DEALER,
if you get still unsolved than contact me personaly
Posted on May 18, 2008
  • 5 Answers
SOURCE: Hitachi 50V710 has a yellowish circle in the middle of the screen
If you're good with electronics you can probably do it yourself. It's the price of the part that hurts ... around $1000.
Posted on Jun 03, 2008
try using colored wire with the copper....colors act as sound carriers and copper acts as power only connect the copper one with ONly 1 color tho .......just try having everything on and just touching the wires together before sodering
Posted on Jun 06, 2008
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
  • 188 Answers
SOURCE: Hitachi TV volume won't work
Is the set in hotel mode?
Posted on Jul 24, 2009
Sylvania wireless headphones
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more :
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Read more :
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Hitachi 50V710 Greenish Tint
Make sure that there is no Magnetic feild around the LCD
Sep 06, 2008 | Hitachi 50V710 50" Rear Projection...
My temp light keep blinking
When the temp light is blinking, that indicates that one (or more) of the cooling fan has stopped spinning. The TV will stay off to protect itself from overheating until the fan is replaced. There are two fans. One is available here: ; the other is .
Retrevo has the manual for the Hitachi 50V710 here: . You will need to enter the code to access the file.
I hope this helps.
Sep 14, 2011 | Hitachi 50V710 50" Rear Projection...
Where is the lamp located on my 50v710 Hitachi TV
The lamp is located behind the lower removable speaker grill on the front of the TV. There will be a lamp door then the lamp is up inside the TV behind the lamp door. Make sure the lamp door is back in place before turning on the TV after replacing the lamp as the set will not work without it installed.
Mar 02, 2010 | Hitachi 50V710 50" Rear Projection...
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
Color on tv is not right after we changed the bulb. Model # 50V710
you need a new light engine, very common problem, you could get hitachi to send you the parts no charge if you press them enough, will save you $600 in parts.
Sep 04, 2009 | Hitachi 50V710 50" Rear Projection...
Hitachi 50v710 Yellow spot
I found out that Hitachi has a class action law suit against them for the light engine problem. I called them and asked what they were going to do for my tv which is out of warrenty. The reply was that they would pay for new light engine. I said what about labor. No they would not pay for labor. I asked to speak to supervisor. I was told by supervisor that the tv had to be inspected by certified repair person. Cost for this was $125 but would be applied towards the total labor cost. Repair guy came to house walked in and said he did not even have to turn tv on to know the problem. We called Hitachi to set up shipment of part. Hitachi told me at that point that they would cover all labor costs also. Part has been installed this week and tv is like brand new set.
Jun 03, 2008 | Hitachi 50V710 50" Rear Projection...
Hitachi 50v710
Light Engine and Optical Block are the same thing ... just different names. It's listed twice many times so that it's easier to search on the web. Hopefully Hitachi will do something about it some day. I plan on letting everyone out there know about it so we can all go after Hitachi. There is a Suit filed against them for the 50v500 set that has the same types of problems ... perhaps it will cover the problems with the 50v710 also. Hitachi did absolutely nothing to help me with the problem. I had to find the part and fix it myself.
Sep 09, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 50V710 50" Rear Projection HDTV-Ready Television Logo
309 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
