Question about Nintendo DS Lite Console
Ds lite i am changing my ds lite case and need instrutions
  • Anonymous Jul 01, 2008
    Hi, My DSwill charge, but When I use It for a little while, it says I need to charge it again.
WHEN I PUT MY DS ON IT GOES OFF
Posted on Dec 07, 2008
    Problem Solver:
  • 6 Answers
Hi
If your still looking for good instructions for replacing a DS Lite case give this one a go . I found it very helpful , when my nieces hinge broke and the top screen ribbon cable got damaged and all it did was go green at power up for a quick moment and the bottom screen flashed and it died.
When you come to replacing the back of the bottom case sellotape is very helpful .Not big bits but enough to hold the volume and power switch covers from the outside after fitting them inside the case . They are easier to line up with the switches on the board inside if they don't move .Be good if they clipped into place .
The Left and Right rear buttons also need a bit of tape to hold them in place cos if they move the little spring will come unclipped .Several times I had nearly got the case back on and I heard a ping noise button still works just not too springy. It seems the small contact switch the button connects with only needs only a small amount of pressure to connect and it pops back knocking the button back .
One more thing don't forget to gently ease the casing over the powerswitch and volume switch .The case won't go over them without help , quite a few people end up snapping the switch of the board.
That it Good Luck
http://www.flickr.com/photos/62647765@N00/sets/72157594277451148/
Posted on Aug 05, 2008
    Problem Solver:
  • 16 Answers
Case? You mean the outer shell of the ds?
Posted on Jun 15, 2008
Just replaced the case on my ds lite, took the top layers off of the lcd screens because i was also changing the colour of the case everything went fine but now the touch screen isnt working?
Take your back case off and check your Digitizer connection if its connected as it has happen a bunch of time when repairing DS, its located next to your right bumper.
Thanks
www.1RepairStop.com
Aug 28, 2011 | Nintendo DS Lite Console
DS Lite
The green light is blinking, no red lights or anything else? The fuse is good as well correct?
Thanks,
Lee
Jul 19, 2008 | Nintendo DS Lite Console
I have a ds lite that works fine but i need to change the casing on it as some parts of the original casing are broken. Can anyone give me or tell me where to get the instructions on how to remove the...
I have written a guide that should help...
DS lite dismantling guide
Hope it helps... if you need any further help oradvice feel free to message me via my profile page.
Regards,
SOD69
Mar 04, 2010 | Nintendo DS Lite
I have lost instrutions on how to play game Hary potter and the goblet of fire game for ds lite
Hmmm thats hard to respond oh i know try going to the computer in google and type ( how to play Harry Potter and the goblet of fire game for ds lite)
Feb 13, 2010 | Nintendo Video Game Consoles & Games
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
How do you play the game?
if your using an action replay just hit the start button
Feb 16, 2009 | Nintendo DS Lite Console
DS 2 Peices
Hey, you need a new outer case and a new top screen. There is a ribbon that comes out of the top screen on the top case and connects to the bottom one. There is a very good chance that ribbon has torn off. So you need to replace the top screen and a new outer case with a new hinge. I would send it to Nintendo, I believe they offer a flat rate service for the Nintendo DS Lite.
Bimmerhp
Jan 22, 2008 | Nintendo DS Lite Console
Ds lite brocken
Hi Mance, I can Repair this, but if you want to fix it yourself, you can get the parts you need from ebay. The Playstation Clinic repairs DS lites as well as other videop game systems. The replacement shell case is quite expensive, like near $40. LCD Screens are not so bad, at under $20 each. if you would like for me to repair you DS lite, contact me at Repairtech@PlayStationClinic.com
Sep 27, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
149 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
