Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite oasis hp washer
The timer button goes from the time it should be to other numbers, and every minute it beeps. It seems to be a problem with the spin speed option, the lights go on up and down, and causes the timer to go crazy. Is there a reset button? Otherwise the washer works, it is just annoying to listen to the beeping every minute and see the number screen go crazy.
  • Anonymous Aug 03, 2008
    washer is flashing lf.will not run?
  • pschlabach Oct 25, 2008
    I have the exact same problem. The timer beeps every minute or so and the time changes back and forth as it washes.
    Sergeant:
    Champion:
  • 291 Answers
Bad control board
Posted on Nov 25, 2008
My Kenmore Elite washer model 110.27062600 stopped working. All the front panel lights are flashing on and off for 7 times then pauses and starts blinking again. The machine will not do anything. No...
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Sep 19, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washer 110.2709
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Cycle stops - F error code
I am having the same problem with the "F" flashing and a beep but no numbers. The manual only says to hit the stop button then the start again. It doesn't give you a problem. It then says if this does not work to call a repair man. Mine is only two years old and we loved. I have never had any problem with it but every review I have read says differently and they seem to happen around the two year mark. It seems they have a malfunction timer that goes off at the two year mark. If you find a solution please post again.
Aug 06, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
278 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
