Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Hub hello i have a hub d link Des-1008D, my problem is that before my connection from router to my comp had no problems.....then i used a hub in between router and my pc now my net gets cut every 40 mins it disconnects then reconnects.....i had check my router.......and router is a linksys. i had checked the dhcp setting and the client least time is set to 0.....so i was wondering how else is this problem happening........appreciate any help!
  • 2 more comments
  • chess1234 Jun 14, 2008
    what you mean by power problem?? yeap im able to connect to the router.........i can access it from my comp here
  • chess1234 Jun 15, 2008
    hmm actually im not sure.....i just bought this hub 2 days ago......shouldnt have problems with ac would it?
    could it be a router problem instead?
  • devil_davil Mar 02, 2009
    i also have the same problem...my internet disconnects every 30 minutes or so and then reconnects itself..please tell me how can i fix this..
    thanks
  • Anonymous Apr 02, 2009
    how do I make the connection faster?
  • 2,794 Answers
There could be a power problem going on with the hub. Are you able to connect fine to the linksys?
Posted on Jun 14, 2008
  • Tim Babcock
    Tim Babcock Jun 14, 2008
    It could be the Ac adaptor in the hub or the power supply in the hub. Do you have a way of testing them?
How to setup my des 1008d in my computer
The DES 1008D is an unmanaged switch. therefore there is nothing to set up. Just plug it in and connect to your computer via a cat 5 cable. Here are the manuals
Link DES 1008D
May 06, 2014 | D-Link DES-1008D 8-Port Ethernet Switch...
Connecting to the modem to dvr
you didnt state the cameras were IP addressable...are they? brand of camera, and which security DVR you were using. Most DVRs wont or dont use the router as it doesnt rotate or change the picture, but I dont know which one you have. Most instead they use a multiplexer .
anyway the manual is here ftp://files.dlink.com.au/Products/DES-1008D/Manuals/DES-1008D_Manual.pdf
for more referance on CC TV try
http://www.aventuracctv.com/dvr_tutorial/default.asp?index=1
Jul 22, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I would like to connect via VPN to an outside network, how do I configure DES-1008D 's firewall to allow this?
How are you wishing to connect? VPN tunnel between the 2 routers? Or just using remote desktop?
Jan 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
How to download the driver of d-link DES-1008D is the model
hey just go to this link http://www.dlink.com/corporate/worldwideoffices/?redirect=%2fdefault.aspx then choose your country, then go to the support tab then at the right side of the sit choose your model then download the driver.
Oct 25, 2009 | D-Link DES 1008D (DES-1008D) 8x10/100 Mbps...
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Internet sharing problem
hi..hmm try to remake new connection and it must all be the same like if your connection is MSHOME the other computer should be MSHOME. if is dosnt work configure your router wan and Lan.
Jul 12, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
To configure this switch
not instal dlink driver, problem for interner connection
Aug 24, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
203 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
