Question about Kenmore Dryers
Kenmore dryer only heats on delicate
My 6 year old 80 series Kenmore (model # 11062802101) electric dryer quit drying on high 3 months ago. Now Medium has failed and can only dry on delicate. What is the cause and how can I fix myself?
How to install rubber belt on kenmore gas dryer number 110.72712101 ?
Posted on Jun 14, 2008
Dryer warms..... but not enough heat to dry...about 10 years old 80 series Kenmore electric dryer
Probably has a broken heating coil...as the temperature goes up it expands and moves from natural position of touching....that would give the false indication of continuity in the coil when it cools back down and touches again. Visually inspect coil.
Nov 02, 2013 | Kenmore 800 7982 Dryer
Kenmore 70 series dryer 110.96573220 only heats on time dry and delicate, not on normal
I would check the temp switch located in the console panel, sounds lile maybe the contact is burned since you have heat on delicate and timeddry.
Feb 02, 2013 | Kenmore 60172 Electric Commercial Dryer
There is no heat in my Kenmore 80 series dryier. The drum is spinning and it seems that there is an air flow coming through, it's just could. The brakers are fine (there are two of them and they are...
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Click on the link below for the details.
Troubleshooting an Electric Dryer Not Heating
Jan 19, 2011 | Kenmore Dryers
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryers Logo
359 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
