Question about Kenmore Refrigerators
Cub. ft. #51262103 kenmore side by side coldspot fef. How much
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Posted on Feb 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Posted on Jun 11, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore 26 cu ft side by side refrigerator 51673100
I think the Adaptive Defrost Control may be your problem part number 12566102 You may find it inside the fresh food compartment and behind the controls where you adjust the tempertaures. I will return with photos and links, Sea Breeze
Posted on Dec 20, 2009
Testimonial: "Great Help Thanks!"
How many cubic feet is a 2003 Sears Kenmore coldspot refrigerator please
The fresh food section is 15.4 cubic ft. and the freezer side is 10. cubic ft.
May 29, 2018 | Kenmore Refrigerators
Kenmore side by side refrigerator 51262103 how to remove drain pan.
Usually, there is a removable grille at the bottom of the refrigerator which provides access to the drain pan. Removal can involve some twists and turns to get the pan clear.
Sep 20, 2014 | Kenmore 51262 / 51264 / 51269 Side by Side...
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
What is the cubic feet of 2000 kenmore coldspot refrigerator model #59592992?
I believe that the full model number is 106.59592992. Since the fourth digit after the prefix is a 9, I suspect it is a 29 cu. ft. capacity side-by-side refrigerator.
I hope this helps.
Jan 07, 2013 | Kenmore Refrigerators
Kenmore coldspot freigerator and freezer isn't cold.
check compressor operations. relay on compressor can fail
Feb 12, 2010 | Kenmore 21.8 cu. ft. Side-By-Side...
2002 Kenmore coldspot 51262103 model number Just hooked it up to water and it runs slow and the ice maker is blinking red.
Not sure if I resolved the issue, but after defrosting my icemaker, with a blow dryer for a second time. It seems to be working fine again.
Is it possible maybe there was some ice build up and every time it added more water for the ice cubes the water level was to high making it impossible for the auger to push the ice thru?
Jun 15, 2009 | Kenmore Refrigerators
Refrigerators Logo
107 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
rlrguitar
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
