Question about Kenwood DPX-501 CD Player
Results after replacing the LCD panel
Hi.
I have the same problem. I ordered the LCD and replaced, but I still have the same problem.
Did you have any luck replacing the LCD panel?
Thanks,
Roberto
Same here. Replacing the LCD does not fix the problem. I wish someone could tell us what the real problem is.
Posted on Oct 26, 2008
I have a Samsung LED TV model UN65EH6000FXZA about 2.5 years old. It's experiencing the "black screen of *****" problem that's evidently common these days. I have sound but no picture.
This could be a lot of things. There could be a loose cable, a bad T-con board, a bad lcd display panel, bad main board etc. This is why television repair shops have an advantage, they can swap parts for free without charge, Then when they find the bad part, they charge you for it. if you order something and are wrong, you now have a spare part. Also manufacturers wont ship a large LCD panel to an end user. In order to troubleshoot this issue you would need meters and scopes unless you want to guess at what the issue is. Sites like shopjimmy.com have a lot of helpful info. I would guess that it is the TCON board, You may want to see what the cheapest part is and try that route. The main board could be the issue too but the last and most expensive is the LCD panel and you cannot replace that. Start by checking cables because if you moved the set or use it a lot, sometimes ribbon cables come loose.
May 27, 2016 | Samsung Televison & Video
Why does my brush roller stop and heat up belts?
Hi! If you have replaced the belt with a new one and your brush-roll is still not spinning, your brush-roll may need to be replaced. Remove the brushroll and clear it of hair and debris. Spin the end caps with your hand. They should spin easily with no tension. Inspect the area on the brushroll where the belt rests on for damages. To order a replacement brushroll click on this link. Search Results It could also be that the incorrect belt is being used with the vacuum. Make sure you are using genuine Hoover parts when replacing the belt. Click on this link to order a replacement belt. Search Results & Search Results
Hope this was helpful!
Jun 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Why does drive belt on Hoover U6434 keeps slipping off. Even new ones.
Hi! If you have replaced the belt with a new one and your brush-roll is still not spinning, your brush-roll may need to be replaced. Remove the brushroll and clear it of hair and debris. Spin the end caps with your hand. They should spin easily with no tension. Inspect the area on the brushroll where the belt rests on for damages. To order a replacement brushroll click on this link. Search Results It could also be that the incorrect belt is being used with the vacuum. Make sure you are using genuine Hoover parts when replacing the belt. Click on these links to order a replacement belt. Search Results & Search Results
Jun 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
My television screen broke how can i fix it or order a new one
You can try using Google to find a replacement screen for your set, but be advised, a new screen almost costs as much as the whole set. Just type in replacement LCD for the make and model of your set andyou should get soome results. There are severeal people who deal in these and your local tv repair can also get you one.
Feb 16, 2011 | Dynex Televison & Video
Need to order a replacement 46" LCD Screen
Sorry,not repairable,because the LCD screen panels are limited produce by the Tvs Corporations.No where u will able to buy a LCD Screen panel for the replament,but except by the tvs corporations themselves.Because it limited production of the LCD screen panels,they will sell it to u the same as a new tv.Might even cost more after the labors of by replacing the LCD screen panel.
May 23, 2010 | RCA L37WD12 37 in. LCD HDTV
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
NO POWER?
HI, try a new wall outlet in the home or business. if the wall outlets are live, try replacing the power cord. if this doesn't yield results, replace the internal power unit(inverter board)
Jun 21, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
It will not turn on.
HI, i would try a new power cord before replacing the inverter board in this case. most of the time, the power cord will fail in these units. if the replacement cord dosen't yield results, replace the inverter board.
Jun 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
HP 2025 20.1" Monitor
Unfortunately, the LCD screen of any screen is always the most expensive part of the monitor, and it usually costs as much as the monitor itself to buy, not including shipping and replacing (unless you plan to replace it yourself). I could not find any replacement screens myself, and they are very hard to find. My suggestion is to just buy a new one. Sorry.
Feb 11, 2008 | HP 2025 20.1" Flat Panel LCD Monitor
Kenwood DPX-501 CD Player Logo
185 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
