Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The opener was turned off once we tried to turn it back on there was no response from any of the openers. any help??
    President:
  • 3,197 Answers
Make sure the small light in the wall control is not blinking. If it is, press and hold the lock button for 3 seconds. The light should quit blinking and your remotes should now work.
Posted on Nov 05, 2010
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
When opening web page links it seems that they want to open on screen 2. I usually have this powered off. When, how do I set the web page links to open on screen 1 only. Loc king the taskbar does not seem...
The easiest method to fix this would be to simply go into catalyst control center (or AMD Vision Engine Control Center if you have latest drivers) and disable the second monitor. You don't need to disconnect it physically so all the cables can stay as they are, just disable it and use your computer as you normally would when the second monitor is powered off. Continue to use it this way as long as you like, but I would suggest rebooting the machine at least once before going back to the same place to turn the second monitor back on, and make sure you actually used some web links that previously would have tried to come up on the second monitor.
Once the second monitor is disabled, no matter what software or setting was responsible for causing the links to open on the second screen, the computer will only have one screen available so it will open on the first one. The software or setting should get automatically reset to remember this and a reboot while the second screen is still disabled should ensure that the setting is saved and whatever was making it open on the other screen will be reset to the proper one. Then you can turn the second screen back on whenever you like and leave it on and it should still open links on your main screen just fine.
Nov 27, 2010 | ATI RADEON X1650 Graphic Card
Aeg oko lavamat 6555 cannot open door no response to buttons F9 flashing
Hi
Error code F9 means an error with motor or motor tacho failure. Try resetting the error by pressing quick and prewashing buttons together while turning the knob to gentle spin. All LED's will glow, now turn the knob back to Off and the machine should work. Hope this helps... Please post back for any further assistance.
Daniel
Aug 29, 2010 | Washing Machines
Machine is locked with water inside
Are you getting an error code E20.because this would suggest a blockage in the pump/filter or drain.To get the water out there is a little hose down by the filter which pulls out a few inches and can be drained into a shallow dish,otherwise if you can get machine near the back door step undo the filter and let it drain outside,once drained get a torch and see if there is anything blocking the filter/pump.The end of the pump blade should be able to turn freely.Oh by the way once the water is out you should be able to open the door.Once you have done all before you put filter back in turn knob to spin or drain and you should see the pump spin.Now if all ok refit filter and check for leaks. Hope this was a help.
Good Luck.
May 01, 2010 | Zanussi ZWF1430W Front Load Washer
My xbox is flashing red /wont open disc tray pls help 3 weeks old
press eject if it dosnt open try to pull it open if it does your belt/gears are slipping if so you can try to reconnect them yourself with a screwdriver if you cant pull it open then you have to send it in for repair
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
I have a jensen 9311ts and the screen on the tv is broke and once in a while if u hit the screen it turns on only for a second then back off kinda like a fade what can i do to fix this?
if you are experienced or just have enough confidence in yourself with electronics... try opening the top of the radio and check the video ribbon. DO NOT TRY THIS IF YOU ARE NOT SURE OF YOURSELF! I am not responsible for any damage caused to yourself or your radio.
Mar 04, 2009 | Audiovox VM9311TS
Screen stays black when the computer is turned on.
It might be that the monitor is not plugged in all the way.
Feb 06, 2009 | HP Pavilion 735n PC Desktop
How do whe open the door of a dvd recorder ?
Try this - I had the same problem and this worked for me. Don't just turn off the unit but turn off and then unplug from the mains. wait 5 mins and then plug back in, turn back on and press the eject button on the unit just once - and wait for it to finish it's start routine - and then it may open - it did on mine - if not, then try eject button again.
Hope this helps
Dec 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Won't turn on.
Fixed my "dead" Sansa by opening the back, removing the battery then putting it back in. This appears to have rebooted the system and now it's working fine. No files were lost.
(I did try holding down the on/off button prior to this but got no response at all.)
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
20 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
