Question about LG 32LG30 32 in. LCD HDTV
I got an American model of LG. i can not tune it by auto nor manual can you please help
  • LG Master
  • 5,796 Answers
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Posted on Nov 05, 2010
I have an lg tv model 37LC2DB - EC I lost all my channels and can not auto programme so I did a factory reset now it says not programmed how do I get my digital TVs channels back
Re-program.
lg tv factory reset, not programmed? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
In my lg smart tv showing not programmed how to program ...
nordstromchicago.com/In_my_lg_smart_tv_showing_not_programmed...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
LG TV Signal Diagnostics, factory reset and manual tune ...
? 25:30
https://www.youtube.com/watch?v=IxKcCbjLD4I
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
Jan 20, 2016 | LG Televison & Video
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
My Tv says Not Programmed
Your indoor antenna will plug into the same RF Antenna input jack as would an outdoor antenna. It will take some time but let the unit go through its entire auto tuning mode. If stations are available in your area and signals strong auto tuning will pick them up.
Mar 05, 2014 | LG Televison & Video
Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have problem with my car radio , its frequency standerd
Some radios have the option to adjust sensibility when scanning the frequency, check in your owners manual if your radio have that option. If you can't find that there or if you don't have it let me know about the brand and model.
May 06, 2009 | 2003 Ford Crown Victoria
LG 32LG30 32 in. LCD HDTV Logo
643 people viewed this question
Steve Allison
Steve Allison
