Question about HP Office Equipment & Supplies
I have a HP Officejet J45550 Printer. Black copies are printing with a smudgy appearance. I have a 901 XL Black ink cartridge - ink level showing around 50%. What do I need to do to get rid of the smudge ?
  • 25 Answers
SOURCE: SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Posted on Aug 21, 2008
leroyal
  • 2120 Answers
SOURCE: ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Posted on Jan 31, 2009
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
Posted on Feb 28, 2009
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    SOURCE: HP Officejet 5510 error "Remove & check color cartridge
    When the error message popped up on my computer there was an option for tech support. I clicked on that. I went to the HP website. then found my way to tech support. I clicked on what printer I had and it set me up with a chat session.
    The person helped me and it is now fixed.
    I pressed Setup then 6 then okay
    then after that was done I pressed setup then 6 then 2 and okay
    now it's fixed...
    I hope that this might have helped!
    Posted on Apr 30, 2009
    My hp office jet all in one printer is only displaying error ,when i turn it on
    HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
    support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
    Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
    A 'Paper Jam' Error Displays on the HP Officejet 4215 a
    Dec 18, 2015 | HP Office Equipment & Supplies
    Hp officejet 4620 does not print with starter cartridge
    If printer is in warranty, demand for replacement.
    1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
    If levels are zero, go for new cartridges.
    2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
    Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
    How do i find ink levels in Windows 8 for HP Office Jet J4580
    It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
    NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
    HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
    http://www.youtube.com/watch?v=RivHgvWCkJ8
    HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
    http://www.youtube.com/watch?v=hzLM5mlkTt4
    HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
    HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
    HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
    Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
    ATASCO HP OFFICEJET J4585
    When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
    Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
    Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
    How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
    slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
    Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
    Print cartridge prob [tri-color] refer to ... doc to troubleshoot
    HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
    Normal catridges recommened by HP are given below :
    01. HP 901 - Black which will print 200 Pages.
    02. HP 901 - Tri Colour which will print 200 Pages.
    03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
    This printer is most rugged one used by Home as well as in offices.
    The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
    Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
    • Print, copy, scan and fax with a single machine
    • Print fast, at up to 28 pages/minute black, 22 color##
    • Fax at speeds up to 33.6kpbs
    • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
    • Preserve important documents for decades without fading1
    Solution:
    Please use the originai catridges for this printer and there will not be any issues.
    In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
    If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
    Jul 21, 2009 | HP Officejet J4680 InkJet Printer
    HP J4500 color cartridge error
    Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
    May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
    My hp officejet j4580 says incompatible black ink cartridge
    I've been in print cartridge hell since I bought a J4580.
    I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
    • Make sure your print cartridges are installed.
    • Unplug the machine, wait 20 seconds
    • Press and hold the # and 3 keys
    • Plug the machine back in
    • You'll see a reset message on the machine, release the # and 3 keys
    • Follow the prompts to set the language and location
    Cross your fingers, hopefully your printer will print now!
    Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    134 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
