Question about Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 250.--After changing the print ribbon and also having the daisy wheel out, the machine will not stay in time or it doesn't print the letter pressed on the keyboard. I had it in time for a short time and then it jumped or slipped so that the letters pressed on the keyboard are not what is printed on paper. I would appreciate any help in what the problem might be and any solution. Walt Kaemper
  • walhal Dec 15, 2010
    I will check and get back to you. Thanks. Right now before looking, I don't think so.
    Genius:
  • 1,456 Answers
Hello
This sounds like a problem with the circuit board.it has shifted out of place,Open your typewriter and move the circuit board to align with the keys on the typewriter.
If the problem persists then you will have to replace the board
Posted on Dec 18, 2010
  • 480 Answers
The new ribbon may be touching the print wheel and causing the trouple
Posted on Dec 13, 2010
Daisy wheel typing random
Most of the time that is caused by a broken print wheel try another one.
Mar 19, 2014 | Smith Corona Wordsmith 100 Typewriter
How to change a daisy wheel and line it up
remove the ribbon to see better. Their is a latch right by the print wheel. Just pull gently toward you and the printwheel holder will pop open. Then lift the wheel out and install the new wheel, Then push the latch back towards the platen or big black roller. It should line up by itself when you turn the power back on.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 29, 2009 | Smith Corona Wordsmith 100 Typewriter
My typewriter is a Smith Corona Word Smith. I cannot get the daisy wheel to align
From the manual of Sr Smith Corona WordSmith 100:
Changing The Print Wheel
1) Move the print carrier to the center of the platen using the SPACE or BS
key.
2) You will see a lever on the right side of the carrier. Pull this lever toward you and
lift out the daisy wheel.
3) Place the daisy wheel into the slot with the characters facing the platen.
4) Push the lever back into position.
5) Press the CODE + = (SETTING) key.
Here is the link for the manual:
http://www.google.pt/url?q=http://www.smithcorona.com/pdf/WS100Man.pdf&ei=26RzSrjIFZmOjAer4KS9Bw&sa=X&oi=spellmeleon_result&resnum=1&ct=result&usg=AFQjCNHgeBMa_etCetMv9Vq-BDehtTGprQ
Jul 31, 2009 | Brother GX-6750 Typewriter
Smith Corona SD 250
I have a Smith Corona wordsmith 250. The Daisy wheel is not aligned with the striker, it is two characters off. How do I fix this alignment??
Mar 26, 2009 | Smith Corona Wordsmith 200 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
MY WORDSMITH 250 PRINTS II INSTEAD OF LETTERS WHAT CODES DO I NEED TO USE TO CLEAR THIS
the markes you see is the print hammer hitting the ribbon & paper. remove the ribbon & print wheel. look close at the print wheel when out of the machine if there are any spaces betwen the spokes a letter has broken off and you need a new print wheel, If just bent slowly strten them out. reinstall wheel & ribbon try it.
C.W.H.
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
Daisy wheel will not stay on wordsmith 100
CHANGING Changing The Ribbon Cassette 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette. 3) To insert a new cassette, place the back end of the cassette on the cassette holder on the carrier and gently press down on the front of the cassette unit it clicks into place. 4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon. 5) Presss the CODE + = (SETTING) key.
Changing The Print Wheel 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) You will see a lever on the right side of the carrier. Pull this lever toward you and lift out the daisy wheel. 3) Place the daisy wheel into the slot with the characters facing the platen. 4) Push the lever back into position. 5) Press the CODE + = (SETTING) key.
It appears as though you have something that is preventing the print wheel from being locked in place by the release lever. It should make a snapping or similar noise when it is locked down.
Dec 10, 2008 | Smith Corona Wordsmith 100 Typewriter
Print Wheel Drive Gear is out of Position
Power up the machine, the "V" groove of the hammer should be center aligned with the "." petal If not 1 remove the ribbon bracket 2 loosen screw of the daisy wheel (element) motor it has locktite on it , slide the motor up or down in its slot until the hammer and petal are aligned. If you cannot correct it this waydue to a lack of travel it becomes a more complicated job may need a typewriter repair man.
Aug 02, 2007 | Smith Corona Wordsmith 200 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
178 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Steve Allison
Steve Allison
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
