Question about Kenmore 24642 Top Load Washer
Kenmore washer just stopped
I started a load of laundry and my kenmore 24642 top load washer just stopped after it was filled. It won't do anything and I have confirmed that the electrical outlet is working and tried putting it on another cycle. I have had it for about 3 1/2 years and never been serviced.
  • 1 more comment
  • cheshercatmm Jun 14, 2008
    The lid switch is out, yes. Shortly after posting I figured this out by pushing a screwdriver way into the opening above the lid switch. I got it to come on for just a few seconds then lost it again. Wouldn't by any chance be able to talk me through replacing the lid switch would you?
  • cheshercatmm Jun 15, 2008
    I will start with this and let you know if I need anymore information. Thank you so much! I searched and searched and could not find anything online to tell me how to get the cover off.
    I was able to get the cover off and get to the lid switch assembly with no problems thanks to the above information you gave me. Again, thank you so very very much. You just saved me a $60 service charge from Sears.
  • 413 Answers
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Posted on Jun 14, 2008
  • Richard
    Richard Jun 15, 2008
    To access the switch, REMOVE POWER, lift the console by one of three ways.
    1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
    2. The trim on either side can be pried off from the top. Grasp the top of the trim and pull forward to expose a screw or insert a small screw driver through the top of the trim and pull toward you.
    3. insert a putty knife under each corner, push to release a latch.
    With console lifted:
    1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
    2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
    3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
    If more assistance is required, let me know.
Kenmore washing machine will not stop filling
There is a water level sensor in the tube and it might be plugged. IT could also be the load selector or the control module.
Feb 10, 2014 | Kenmore 22642 Top Load Washer
Washer filled with water but won't do anything
AT the time that you describe, the lid switch must be closed. Check that switch.
Jun 25, 2011 | Kenmore 24722 Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
This is a typical symptom of a defective or loose lid switch. If you open and close the washer lid, you should hear a clicking noise as the lid switch activates. The lid switch is usually located on the right-hand side under the washer casing rim. It is activated through a small slot, by a plastic piece on the lid called a lid strike. There are two mounting screws adjacent to the slot that hold the lid switch in place. Sometimes the screws come loose, or the lid strike breaks off, causing the switch not to activate. Or..the switch simply fails over periodic use. This results in the symptoms you describe. The washer fills, but fails to spin or drain. This is a simple repair that you can accomplish yourself. For step-by-step instructions, please refer to the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require assistance in locating replacment parts and/or have further questions, please post back with your complete model number (located aorund the tub rim), along with your comments. That way I can assure the accuracy of any part numbers.
NOTE: Use care not to slam the washer lid. This can also cause premature failure of the lid switch components.
Jun 16, 2008 | Washing Machines
It won't agitate
after it fills do you hear any sound and does it go to spin on its own or do you turn the timer your self it could be a bad pressure switch thats what we are trying to determine
Feb 12, 2008 | Kenmore 24642 Top Load Washer
Kenmore 24642 Top Load Washer Logo
190 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
