Question about Frigidaire FAH08EJ1 Air Conditioner
Frigidaire air conditioner not working
The outlet is energized and the thermostat is set to the max cool setting and it will not turn on. What could be the problem? Is there a fuse internally that could be blown?
SolutionGuy
  • 331 Answers
SOURCE: Emerson Quiet Kool 6GC53 Air Conditioner
Chesapeake, given your symptoms you'll be looking at installing a new Selector Switch. But, before you go there... UNPLUG THE UNIT OR SHUT OFF THE BREAKER!!! Your selector switch does two things at a time, It energizes the fan motor (which it IS doing) and energizes the compressor at the same time. The voltage to your compressor goes from the wall into the selector, out of the selector, through the temp control then to the compressor. When the temp control is satisfied, it interrupts power to the compressor. The click you hear is the temp control being NOT satisfied and trying to send power to the comp. But if there is "no power" to send (i.e., the selector switch has failed)the compressor won't know to engage. Remove the front panel and filter. Remove the control box housing. Remove the knobs from the controls. You will now see the selector switch. Remove the 2 screws that fasten it (don't remove the wire yet!) and install the new switch. Then, one wire at a time, remove the wires from the old switch and install them on the new one. ***If you have an OHM meter, check the temp control before ordering a selector because this may be the problem and NOT the selector! To do this... remove the 2 wires from the temp control, set the control to "coldest". Then with your meter, test OHM's between the terminals. If you see "zero" OHM's, it's good. If you see no change in your meter, it's bad and THIS is the source of your problem. If you don't have a meter... you can test using this procedure... cut a 6" length of wire and strip the ends to about 3/8", twist the copper ends tightly. Remove both wires from the temp control, then insert one end of your jumper wire into one terminal and the other end into the other terminal. Make sure the "jumpered" wires are away from anything metal!!! And plug the unit back in. Now turn the unit on. If the unit fires up? It's the temp control, If not? it's the selector switch. Here's a link for parts...http://www.repairclinic.com/0080.asp
Posted on Aug 09, 2007
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 15 Answers
SOURCE: Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
Posted on May 26, 2009
  • 26 Answers
SOURCE: Air conditioner will not turn off, thermostat
Is there a heat source close to the thermostat, plug in transformer for a phone mabey, table lamp? If not then you have to have a bad thermostat. Any possible heat source from inside the wall? Will it shut off if you turn the system off? Turning power off to the furnace will shut everything down. If no heat source is driving up the indicated room temp, replace t'stat.
Posted on Sep 18, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
Why does lenox heat pump not heat in normal heat mode?
The thermostat is not a heat pump thermostat or it is not wired or set up correctly.
Feb 05, 2015 | Heating & Cooling
Frigidaire FRA256ST2 compressor stays on for about 3 mins then goes off for about 3 minutes, we have the temp set for 76 and it says 80 on the thermostat
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 02, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Arcoaire NFCX 3600C1 heat pump - blows cold air even with emergency heat on
Check the O/B setting on the thermostat and equipment to insure the reversing valve is energized during the proper heat/ cool cycle. Also check the thermostat wireing to insure electric heat element is set up.
Feb 01, 2010 | Heating & Cooling
Installing 1 1/2 ton Weatherking Heatpump and ADP WAK351807P2 air handler 1 /1/2 with 7.5KW back up heat kit. Can't seem to get the thermostat hooked correctly. I understand the Weather King product...
O energizes the reversing valve when the thermostat is set for COOL. B energizes the reversing valve when the thermostat is set for HEAT.
The O/B is usually a orange or black wire.
You can't hurt anything if you choose O or B incorrectly. Hook one of them up and run the unit. If set for COOL and the unit runs cool inside it is correct. If set for COOL and the unit runs warm inside it is not correct.
If the inside temp is opposite from your setting change the wire to the other terminal.
Remember to disconnect power from the air handler when changing thermostat wires.
The defrost control board on the outside unit should be marked correctly for O or B.
Your thermostat may have a slide switch rather than a separate terminal.
Oct 30, 2009 | Weather King 10AJA6001AH Air Conditioner
Thermostat position?
The thermostat control alows you to set it at whatever your desired room temperature is. It will keep the compressor on until it reaches your desired setting and then turn the compressor off.
Aug 14, 2009 | Frigidaire FAH08EJ1 Air Conditioner
My Goldstar GWHD5000 window type air conditioner is running but it does not give out cold air. The thermostat setting is on max and the blower adjustment is on high. What do you think is the possible...
Do you hear the compressor running? Just because the thermostat is on high doesn't mean it is calling for cool. Do you hear a click or snap when the thermostat is turned from low to high? Possibilities are: Thermostat, compressor start relay, overload, gas leaked out, compressor failed.
eric
Jul 01, 2009 | Heating & Cooling
Heat Pump and fan work fine, but will not blow cold air on AC setting
The reversing valve coil may be bad or no power to it during cool. Most heatpumps are set to have the coil of the reversing valve energize in the cool mode. The heating mode is the fail safe mode if the rev valve fails to energize. Check this and let me know.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
My problem is when I turn on my air only kick in for a minute of cold air then it shuts down then warm air comes out for five minutes maybe less. my setting are at max cool thermostat at 7. at these...
if it is in the middle of winter that you are doing this it has still got a very slim chance of doing what you want... it is a thermostat afterall which is preset by the manufacturer, take the settings off automatic and turn onto cool only.... atleast that way you will not generate a heating signal
Jun 16, 2009 | Heating & Cooling
My air conditioner doesn't turn on, what do I look for?
If your room air conditioner doesn't go on at all: 1) Check the power source first: be sure it's plugged in and turned on. 2) Then check the outlet by unplugging the air conditioner and plugging in a light that works (only for standard-voltage models--do not plug a light into a 220/240-volt receptacle!). 3) If the light doesn't go on, the circuit has probably overloaded--check the electric panel or fuse box and reset the breaker or replace the fuse. 4) If the light works, it's likely that the air conditioner's switch is faulty or the thermostat needs adjustment or repair. 5) Be sure the thermostat is set to "cool" and below room temperature. 6) Refer to the manufacturer's instructions for thermostat repair. If adjusting or repairing the thermostat doesn't solve the problem, unplug the unit and call an air conditioning technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Frigidaire FAH08EJ1 Air Conditioner Logo
177 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
