Question about Philips VOIP8411 IP Phone
I can dial out but hear nothing after target phone answers
New phone, verified latest firmware. You can hear it ringing but it goes quite when the call is answered. To verify, the call worked fine when calling from skype on the computer with a headset. I read one solution which said to unplug the batteries and restart the headset; but that didn't work. I also read somewhere (on another issue) where Philips suggested leaving batteries for 12 hours; which I'm in the process of waiting.
My network is secure (requires a password for computers to connect). I didn't see any setting to enter that password when setting up the phone. Could this be related to my problem, or does it somehow bypass my network secuity?
I have the latest firmware. Any suggestions appreciated.
  • rtcondon Jun 14, 2008
    It works fine now. What solved this problem for me was leaving the batteries out of the handset for just over 4 hours (not 12 as I first wrote) with the base unplugged for the same amount of time.
  • Brett Duxbury
    Brett Duxbury Mar 23, 2017
    do you have a bluetooth handsfree in your car that might connect up with your phone when the call is made ?
SOURCE: Philips VOIP841 Cannot connect to Skype - Adsl problem?
Right. I've fixed it!
Here's what I did.
- You need to upgrade to the latest firmware. This is available from the Philips website. Make sure you select exactly the model of your phone. There are some instructions about how to upgrade the firmware in the manual
- Then you need to perform a reset of the system. ie: get a sharp tool and ram it into the tiny little hole on the black box which comes with the phone. If you don't do this after upgrading, it doesn' t work.
- One other tip is to check the firewall settings on your router allow the traffic in/out as well.
I called the Philips service center, and they were a bit useless, but they said if it doesn't work you could try taking the batteries out of the phone for 4 hours. Hmmmm... only try this if the above doesn't work!
Good luck.
Posted on Nov 12, 2007
  • 4 Answers
SOURCE: Phone does not work for teleconference services that require a pin number
I've found dialing numbers to navigate automated answering systems through Skype to be unreliable in general. Sometimes it works, sometimes it doesn't. This holds true for using the numpad on the keyboard, my free-1 usb skype phone, AND now the new Philips VOIP8411B I got in the mail yesterday. I'm not surprised that the Philips doesn't work, since I've had the problem before, but still disappointed...
The only way I've been able to work around this problem is to make the call on the computer and dial numbers through the on-screen number pad (using my mouse) to get through automated systems that don't work with a handheld device. Yes, this defeats the puprose of buying and using all these cool gadgets like the Philips and the free-1, but only for these certain types of calls. And even when I use the on-screen number pad, it still doesn't work sometimes. That's when I start punching numbers frantically and hoping a real person will pick up the line... lol
@Pat56 - If you use teleconferencing so much, maybe it would be best just to do it through the computer with a USB headset instead of using the Philips VOIP8411B...? Just a thought.
Posted on Feb 12, 2008
SOURCE: Phone rings, but once answered its not possible to hear a voice.
Actually I had exactly the same problem. I did a simpler version of the above. I switched the base unit off/on and took battery out of phone then put back in again. As if by magic it now works again. So if in doubt - re-boot!!!
Posted on Feb 27, 2008
SOURCE: Philips VOIP321 not responding or connecting with skype
I have the same problem
Posted on Sep 18, 2008
SOURCE: philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Posted on Apr 21, 2009
When using the phone we have no dialing tone at all, but you can still dial out , no ringing tone however when the phone is answered you cannot hear the other person
First, plug the phone into another known working jack to see if it is the phone or the jack. If it still does not work in the new jack then replace the cord. It that does not work then it is your phone. If you only have the one jack, take it to a neighbors to verify if it works or not. If none of that works then it is the phone itself.
Aug 04, 2014 | BT Synergy 5500 Dect Single Cordless Phone
Why does my phone only rings once, calling party hears a couple of rings and then goes to voicemail. goes to dial tone when answered after first ring.
Press menu, go to settings then scroll down to ring count and set number of rings before it goes to voice mail.
Jul 18, 2014 | Panasonic Lands Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
The phone rings but cannot hear either end
I had the same problem with the latest firmware (Version 250). It was working perfectly earlier but this problem arose suddendly. I fixed it after many days by installing an older firmware (Version 245 in my case) and then installing the latest firmware again (Version 250).
You can install the firmware by going to:
Menu > Settings > Advanced > Firmware Update > All Firmware vers. > (select firmware version) > Install
Please make sure that you don't loose power and internet to your base station during the update. Also, your handset should be fully charged.
Hope this will help everyone who has the problem.
Apr 17, 2010 | RTX DUALphone 3088
I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
Aug 21, 2009 | Google Android
Samsung U900soul
go to the store you got the phone and get angry with them until they fix it for worked a year ago when my sgh-zv10 had the same i have problems with my samgung u900v.the touch screen does nothing when i touch it.i mean it gives no is like talking to a dead monkey.
Oct 29, 2008 | Samsung U900 Soul Cellular Phone
My Bluetooth interation suddenly stopped working
Many problems related to pairing can be corrected by verifying that the latest firmware is loaded to the GPS unit and the phone. To update the firmware on the GPS, please use the WebUpdater program. To make sure the phone has the latest firmware updates, please contact the phone service provider for more information.
One additional tip is to always pair the phone with the GPS from the phone itself. Do not attempt to pair to the phone from the GPS unit.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
I've lost my manual and need troubleshooting help
Our phone decides to call screen people so the answering machine goes on after 2 rings. We can't find the manual.
Dec 10, 2007 | Uniden TRU8885 Digital Answering Machine
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
Philips VOIP8411 IP Phone Logo
65 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
