Question about Motorola Mobility RAZR V3
Usb cord i have a usb cord and a rar v3m but when i hoof it up to the computer it makes a noise and it say's no device is conneted on window media player so how do i set it up ?? help plz
    Brigadier General:
  • 7,752 Answers
You need to install the MPT - Mobile Phone Tools Software and install the usb drivers for the phone so the pc recognise it
Posted on Jun 25, 2008
How can I download music from computer to Mp3 player
1. Get on Computer 2. Plug in USB cord in the USB slot on the main computer. 3. Open My Computer and it should say on the side there is a USB device or the type of MP3 players name. 4. Open up another My Computer window. 5. Goto the location your music files are located and make sure both windows are visible on the screen. 6. Drag your music files to your MP3's music file section. Sometimes the music files wont work so first try the WMA (windows media audio) file first. If the WMA files dont work on your MP3, convert them to MP3.
Jan 06, 2014 | Craig Cmp616f Mp3 Player
Eclipse V180 Series 8GB USB Help
Does it came with any driver/software cd ?
Dec 26, 2013 | Eclipse Audio Players & Recorders
When i conneted my player with computer then i
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 27, 2010 | Sony Walkman NWZ-B142 MP3 Player
How do i put music,pictures ect in the device
Connect your MP3 player via USB cable to the Computer.
when you connet mp3 player, it will automatically running.
If not running go to My computer - Select Removable Device and Open -
Copy Music File or Picture from your computer and paste to your mp3 player.
Feb 08, 2010 | Audio Players & Recorders
Player will not register plugged to pc but light comes on player
Try unplugging the player, rebooting the computer and then plugging the device back in. If that doesn't work see if your player has different modes for the USB connection and make sure to change it to storage device. That will allow it to mount as a drive viewable in Windows(assuming this is Windows). If this is a version of Windows prior to XP you may need a device driver to make the player work. If this is Linux or a MAC most likely you will need a device driver of some sort.
Nov 17, 2009 | Sylvania SMPK2062 MP3 Player
Computer won't read songs on the mp3
did you make sure your computer read the device was connected?
did you use media-player (windows)?
is the usb cord broken?
does the mp3 have enough charge in the battery to connect?
Hope these questions can help you find the problem.
Feb 08, 2009 | SanDisk Sansa e260 MP3 Player
No cord and instruction book
the model you aks about should have come to you with both manual and USB cord. you may find a generic typeA to typeB USB will work though. When connected open Media player and click the tab SYNC to copy music to the device (you can also lower the compression as you don't need CD quality for earphones/mp3, this will give you extra space for songs on your mp3 player)
Jan 18, 2009 | GPX MW3836 MP3 Player
MotoRazr V3m transfering music from minisd card to a ringtone
You may need to have some type of file converter on your computer kind of like windows media player has or I-Tunes. These will convert on command.
Sep 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Motorola Mobility RAZR V3 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
