a ring moved out of place on the face. Do I need to remove movement to access the face?a ring moved out of place on the face. Do I need to remove movement to access the face?
AnonymousMar 20, 2014
i need a baterry mosel number for the battery for a lucien piccard watch 26495bki need a baterry mosel number for the battery for a lucien piccard watch 26495bk
AnonymousMar 27, 2014
I purchased the watch in 1973I purchased the watch in 1973
You can't post conmments that contain an email address.
I have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Lucien Piccard is a brand with distant Swiss heritage, which now has the same address as Invicta, SWI group, Stuhrling/Akribos and World of Watches. Asian manufacture and always a deep "discount" from list price. This isn't to say that they don't have some great looking watches, only intended as a bit of background to the company.
i only found some for women sorry !!!
http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
This as with most fashion brand watches has to be ordered through the manufacturer. Contact the manufacturer direct or see a retailer for instructions.
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out. * I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
The arrows you are seeing are for sizing the band. I cannot find 26311SS in my data base, but I have a good idea what you need to do. The curved piece is a safty that goes over the clasp. Take something like a round toothpick and with the curved piece going to the right like this: ( put the toothpick under the far lefthand side, in the middle and see if you can pry it up ,( I say use a tooth pick so not to scratch up your watch) it should flip over to the right.Check and see if there are any spring loaded buttons on either side of the clasp, if there is push them in ,and lift to your left If there is no buttons just pry up towards your left. If this dosn't work PLEASE let me know, and I will find the exact watch and we can go from there. Good luck!!
