Question about HP Pavilion dv1000 Notebook
Sony vio laptop to hp dv100
Hi can any one tell me if i can connect two laptops as my monitor on my hp will not work so i thought i could connect then together so i can use the one that the screen has broken on any ideasa
thanks
larry
  • HELLO?
Posted on Jun 14, 2008
    President:
  • HP Master
  • 1,314 Answers
No, that won't work. You can attach an external monitor to it though.
DVI to VGA connection problem
i think you can use it only for the projectors etc and you should not use as monitor by this way
May 24, 2008 | HP Compaq nc6000 Notebook
I cannot connect to video projection my labtop is vio VGN-SZ28gp Video projection cable do not recognize my labtop!
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Apr 18, 2011 | Sony Vaio VGN-SZ28GP/C Laptop Charger...
When i turn it on nothing to see except broken line in diff collor or i mean duistroited cant even see the vios coming from thescreen
Please confirm if the lights are blowing on your notebook,
If you have any extra monitor try to connect that to the VGA Port of your Laptop. and switch it on. If display is coming on that Monitor it means the Laptop LCD having some issues.
Sep 24, 2010 | Sony VAIO VGN-FS790 Notebook
How do i fix my sony vio vgn-fz21e notebook?on boot up,shows strange lines and texts.i have re-installed os but fault persists.please help
Try to connect your laptop to an external monitor or TV and see if it works okay. If it does not then your graphics card is bad. If so you will need to either replace your graphics card or your entire motherboard.
Aug 14, 2010 | Computers & Internet
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Sony vio pcg7z2L
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | Sony Computers & Internet
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Buying sony vio
best to buy here, wide variety if your not pleased take the product number and paste it into amazon followed by the words sony vaio! I LOVE MY VAIO YOU WONT BE DISAPPOINTED!!!
http://www.sonystyle.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10551&storeId=10151&langId=-1&categoryId=16154&SR=sony_search_sem&SQS=Laptop
Aug 23, 2008 | Sony VAIO VGN-FE550G Notebook
HP Pavilion dv1000 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
