Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
I have an electric fire place. The blower is fine, however, the light that ulluminates the logs and makes it look like a real fireplace is out. How can I fix it?
I just repaired ours and it is quite simple,if it is the same type.First remove the front cover frame, then with a screw driver repove the clip at the top of glass,ease out the glass and lift up to remove.Remove the plastic logs and you look inside and you will see your burnt out lights,remove them, buy the same type and replace them, normally they are standard candleobra light that you can buy at any hardware store.
Posted on Nov 12, 2010
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Electric fireplace
Heat and fan work fine for me, but the fire design for the logs and the wall wont turn on. I also lost the remote for it.
Jan 15, 2014 | Heating & Cooling
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
We have a Marco fireplace and the damper does not shut. I push the leaver inwards but nothing catches to keep it closed. We purchased this house and the fireplace was replaced with Gas Logs but still...
when the gas logs were installed the vent damper should have disabled. it sounds like this was done.it is unsafe to close the damper with gas piped into the fire place. sometimes a "u" block will be placed over the damper blade. if the gas has been removed and not piped into the firebox anymore it would be safe to remove this
Jan 27, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Gas fireplace question
Simulated gas log fireplaces usually don't have a blower of any type. They depend on the radiant and conducted heat much like there was a real wood fire in the firebox. Look in the manual to determine if a blower was included, but I doubt it because of risk that CO would be propelled into the living space.
Jan 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Oct 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
133 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Steve
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
