Question about SanDisk Sansa e260 MP3 Player
E260 Wont Turn On
Running WindowsXP Pro
Plugged into a wall charger everything works fine as long as it is plugged in. Changed mode to MSC and plugged into the PC. Formatted successfully and updated Firmware. Same problem.
Changed to new battery and charged overnight. Full charge. Unplugged from PC. Same problem.
While connected to PC displays "Writing" for a long time before displaying "Connected".
Just wont turn on unless connected to wall charger.
  • Max Drive Jun 14, 2008
    It is already set to WindowsXP style.
  • Max Drive Jun 15, 2008
    After all the various updates and other wonderful attempts to drive me crazy I removed the new battery and carefully examined the interior of my e260. The battery connections seemed a little low (slightly bent down) so I very gently bent them up to a point where they would center on the battery contacts. It WORKED!
    Apparently someone bent them while replacing the battery and at least one was hitting the plastic battery casing instead of the contact!
    I now have a working e260 with a shiny new battery in it.
On the desktop click right button and click properties.now go to the apperance below the windows and buttons chane it as windowsxp style.
Posted on Jun 14, 2008
Samsung will not turn
Could be overcharged let set for one week no charger
Aug 06, 2014 | Samsung GALAXY NOTE PRO 12.2IN 64GB WHITE
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
E260 - now showing two empty directories (but I still have my music)
try formatting it. to do that, simply scroll down to settings, and in settings hit format. you'll lose everything that was on it tho, if that don't work then try updating. if your unsure how to update go here.
and install the program.
Nov 06, 2008 | SanDisk Sansa e260 MP3 Player
How do i update my firmware
It is pretty easy. If running Windows just download the Sansa Updater (see link below) and install it.
Then, use the Mac/Linux instructions (even if running windows!) to put the e260 into MSC mode- turn e260 on, switch e260 hold switch to on, press and hold the e260s LEFT button "<<" while you plug the USB cable into the e260.
For me (running Windows XP) the Sansa updater automatically detected the e260 then and updated the e260's firmware.
Links to the updater, and alternative complete instructions for Mac/Linux are here
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 07, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
  1. Turn on the e200 v2
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the e200 drive(s) to show up
  6. Follow instructions below and drag files to the e200 drive
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
Cant find mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Sansa Recovery Tool
PDF how to use recovery tool
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
Explanation:
The e200 can operated under two different modes, MTP (Media Transfer Protocol) mode and MSC (Mass Storage Class) mode.
To see the MicroSD card as a Removable Disk, the e200 must be in MSC mode. The following screen shots show how the "My Computer" screen will look when the device is plugged in under each mode.
MTP Mode
MSC Mode
Solution:
To change the mode from MTP to MSC go to the Main Menu of the e200.
If you're e200 is plugged into your computer, please unplug it first.
1) Scroll to the "Settings" > "USB Mode" > "MSC Mode" and push the select button.
2) Connect the e200 to the computer using the USB cable provided.
3) Go to "My Computer" and there will now be two Removable Disk drives similar to the MSC Mode image on top.
Answer ID: 356 Created: 03/23/2006 Updated: 03/24/2006
For Products: MP3 -> All Sansa e200 Series , Mobile Memory Cards -> All microSD and microSDHC
Category(s): Audio Player , Computer Only-> Windows XP
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa E260's screen is white and it won't turn off
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
