Question about Whirlpool GBS307PR Electric Single Oven
I was using the auto clean feature on the Whirlpool Super Capacity 465 when it began to smoke heavily from something that was spilled in the stove. I hit cancel and the door remained locked. Now it keeps beeping with the error message F5E1. I have tried to unplug it but it has not cleared the problem or unlocked the door. This oven is in an Ambulance base and needs to kill the beeping so the crews can rest
SOURCE:
fridgetech
  • 473 Answers
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Posted on Nov 03, 2007
SOURCE: whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Posted on Feb 03, 2008
SOURCE: oven door came off
Just found this posted by tech17 (THANK YOU SO MUCH!) and it worked!
POSTED BY TECH17:
i posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Posted on Jun 09, 2008
SOURCE: Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Posted on Nov 25, 2008
iwillfixforu
  • 619 Answers
SOURCE: Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Posted on Mar 07, 2010
SELF CLEANING INSTRUCTIONS FOR WHIRLPOOL SUPER CAPACITY 465 ACCUBAKE
It's best to remove the racks. However you can go on line to download a free manual.
Dec 31, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Super Capacity 465 gas range. I have no idea how old it is. The oven door refuses to open. I did use the auto clean feature about a week ago and have used the oven since with no problems...
Hello & Welcome to FixYa
The problem is with the door lock assembly that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Sep 12, 2011 | Whirlpool Ovens
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool GBS307PR Electric Single Oven Logo
64 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
