Question about HP Color Inkjet cp1160 Printer
HP cp1160 printer power light flashes indicating "the printer is busy"
I recently did a number of envelope addressing. During which a few got caught up in the rollers and jamed. Not all pieces came out, yet the remainder of printing went well. A day later I tried duplexing some pages and it failed three times, however the missing pieces from the envelopes came out.
I removed the printer, took out the duplexer, dusted with compressed air the entire unit, cleaned the rollers with roller rejuvenator, re-installed, turned on, and now the printer power light flashes indicating the printer is busy. I note that the printer carriage is not docking on the right side any longer, and any job sent to the printer produces a "failed to print" window.
Any suggestions?
Cordially,
Bob
  • HP Master
  • 2,794 Answers
The duplexer might not be seated properly in the printer causing the carriage to jam. See if you can reseat it.
Posted on Jun 14, 2008
I can't reset printer. The green light is flashing and screen is saying busy
Sounds like info is "stuck" in the buffer. To clear it out, turn the printer off, wait three minutes and turn it back on.
Nov 13, 2012 | HP OfficeJet J4580 All-In-One InkJet...
Hp officejet 6310xi doesn't want to print envelopes. prints everything else fine
Step One: Correct way of Feeding Envelop in Officejet.
You can refer to this webpage mentioned below for better understanding for the steps:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=buu03053
Step Two: Print the Envelop
  1. Right click on Printer icon and select Printer Properties.
  2. Now, Click on Printer Preferences
  3. Go to the "features Tab".
  4. Select Plain paper
  5. Select "Landscape"
  6. Under sizing options select "More". this brings up more options select envelope #10
  7. Put dot in "Scale to paper size"
  8. On next line click the down sign and select envelope #10 again from options.
  9. Click OK.
  10. Now, try to print using these settings.
Step Three: Change the Settings.
You can refer to this webpage mentioned below for better understanding for the steps. The steps are same for windows 7 and windows Vista operating system.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01518768
Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the address box.
Step Four: Setting up the envelope size in Microsoft Word (Windows)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01913438
Feb 02, 2010 | HP Officejet 6310 All-In-One InkJet...
I have wedding envelopes that I am trying to print on that are A9 size. The delivery address prints (sometimes) but the return address will NOT print. The "Check Printer" light always starts flashing, and...
Did you set the printer to use A9 envelopes? You can go to the printer software or printer options and set the printer to print on the size paper you select.
Jan 24, 2010 | HP Photosmart C3180 All-In-One InkJet...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    How to clean printer heads HP cp1160?
    In the HP software suite for that printer there is a program for cleaning and aligning the heads.
    Jun 23, 2009 | HP Color Inkjet cp1160 Printer
    No paper light ligted even after paper is loaded
    Flashing resume light also can mean:
    1. cartridge is missing or an incorrect print cartridge is installed
    2. cartridge is out of ink
    3. dirty cartridge contacts
    4. paper jammed
    Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
    Apr 25, 2009 | HP DeskJet 690c InkJet Printer
    Cannot print envelope on MX310
    Note:
    • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
    • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
      Note:
    Printer Driver Settings:
    1Select Envelope in Media Type.
    1. Select the size for envelopes.
      * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
    3. Select Landscape in Orientation.
    Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    How to address an envelope?
    Use Microsoft Word's envelope address feature (or Open Office).
    Feb 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
    My HP business injet 1100 just stopped printing, why?
    In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact HP at 800-588-3554 and Get the Printer Replaced........ Good Luck
    Jan 28, 2009 | HP LaserJet 1100 Printer
    Envelope Formating Using Word 2003 & HP Laserjet 3055
    The problem occurred when I used network but not direct connection. It turned out I had the wrong driver for the network connection. I learned this through HP's online troubleshooting tool.
    Sep 30, 2008 | HP LaserJet 3055 All-In-One Printer
    HP Color Inkjet cp1160 Printer Logo
    143 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
