Question about Motorola Mobility H700 Wireless Headset
Trying to connect to bluetooth
Hi i got this headset from a friend and its compatible with my phone i think and i have no clue to how to connect it with my phone i have gone to the connections part and then chose bluetooth then it told me to go to device well when i did it said nothing has been found. Maybe my phone isnt compatible i dont know but it would just be really nice to hook it up.
    Sergeant:
  • 287 Answers
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Posted on Jul 01, 2008
Htanx soo much my friend i am harry canada
Posted on Jul 09, 2008
How to pair bluetooth with nexus 7
Hi on the bose website it says- No, the Bluetooth mobile phone connectivity is for communications only. so using it on tablets and such would not be compatible. Thanks
Feb 01, 2014 | Bose A20 Headset with Bluetooth - Airbus...
I have an LG Keybo phone and am trying to pair it to a motorola bluetooth headset but it won't connect it. I noticed the version of the headset is 2.1 and the version for bluetooth on my phone is...
You will need the same version of bluetooth and the headset. Version 2.1 is backwards compatible with version 1.2. That being said, your phone will need to have the higher version of bluetooth technology. So therefore your headset will not work with this phone.
Mar 04, 2011 | Motorola Mobility Bluetooth Hands Free...
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I cant talk to anyone and how do you talk to them
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Oct 21, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
Unpairing bluetooth headset without mobile???
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
Oct 11, 2017 | Nokia N76 Cellular Phone
Connecting to my bluetooth
maybe it is not compatible with that model headset...but you should take it to a mobile shop and have them try to connect it for you.
Aug 22, 2008 | Motorola Mobility RAZR V3
Motorola Mobility H700 Wireless Headset Logo
71 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
