Question about Brother Office Equipment & Supplies
Intel Fax 2820 Back cover open - Brother Office Equipment & Supplies
  • ojdidit Jun 14, 2008
    K........thanks for any & all your help!!!!!!!!!!!
When I downloaded and try to install the Brother software, the installation will not continue past the instruction to connect the USB cable to the computer. I uninstalled the software (it was not installed at all) and retry again and same problem. (I have Window XP, USB interface cable, Fax 2820)
Posted on Sep 03, 2009
  • 134 Answers
There is a problem with that machines exit sensor not swinging properly. Open the back cover and look for a sensor in the middle. Try to swing it gently to loosen it up. Close the cover and try it again. If no help, then you will need to check. brother-usa.com.
Posted on Jun 14, 2008
Error message "close back cover"
1. Maybe a Paper Jam below the drum
2. A lever on the inner back cover is missplaced
Mar 16, 2015 | Brother IntelliFax-2820 Laser Fax
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
Open the front cover and remove the drum and toner(cartridge).
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 31, 2010 | Brother IntelliFax-2820 Laser Fax
Fax display says, close back cover even with back cover closed.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
The brother fax 2820 keeps signaling to me to close the back cover no covers are open
Open that back cover, and you'll see another, black plastic plate that also can be pulled to swing down. Running across that plate is a skinny black rod. At the right-hand end (when you're peering in the back of the machine) it has a couple of right-angle bends, ending in a vane that should swing through a curved slot in the side wall inside the machine. That vane interrupts a sensor to tell the machine that the door is open or that paper is jammed in the back. Sometimes it gets bent with the vane outside the curved slot. Gently bend it enough to drop it into the slot, close everything up, and try it out.
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Mar 05, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
185 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
