Question about Western Digital Computers & Internet
The Green Ring just keeps flashing, when plugged in On my computer it does not have a Drive Letter and when turning off the computer I have to Unplug My Book Hard drive for the computer to shut down, the computer had a hard time booting with the drive took I have to unplug to get to run Windows, External Hard Drive, also tryed to reset the drive it worked once but after the it didn't
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 05, 2010
The tv will flash a green light and will turn off, it doesnt turn on either when you power it on
if the green light is a flash on screen with retrace lines most likely the video driver ic on the green crt board , just take the speaker grill .
theair should be a way to get to crts. the one in the center is the green crt. the green video driver ic is an inline 24 pin ic.
to test unplug the video drive plug leading to green crt board turn tv on .if it comes up its a bad ic.
if not unplug the crt socket ,and try to turn it on if it comes up
bad crt internal short hope this helps, butler
Oct 02, 2016 | Televison & Video
SANDISK 32GB USB FLASH DRIVE
Things to try: -
1. Look in Control Panel/Computer Management/Storage/Disk Management and see if it appears. Check the drive letter if not there changer it.
2. Unplug any eternal drives and then plug the disk in. I have experienced where the drive letter is reserved.
3. Try it in another computer particularly one that has an inbuilt reader.
4. If this fails download Testdisk and see if it recognised. You can fix boot sectors and bad sectors with this.
Sep 06, 2017 | SanDisk Lot Of 5 32g 32gb Cruzer 2.0 Usb...
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
How do i burn a dvd from my external unit to my burner in my laptop
Depends on what operating system you have............
XP:
1) Left-click on Start > My Computer
Look at the drive letter that corresponds with the external drive.
It may be E:, or F:, or G:, or so forth.
[ D: drive is usually reserved for the optical drive in your laptop. C: drive is the Harddrive ]
2) Double-click on the drive letter
Open the folder you want, (Double-click on it), Right-click on the file name, Left-click on Copy
Vista and Win7:
1) Click on the Windows logo button
2) Click on Computer
3) Double-click on the drive letter that corresponds with the external drive
4) Double-click on the folder you want (Open), Right-click on the file name, Left-click on Copy.
Don't know what drive letter corresponds?
Look at the drive letters with a device listed to the right.
Memorize, or write down the drive letter that has a device listed to the right of it.
Turn the laptop off. (Properly)
Unplug the external unit.
Turn the laptop on, and go to My Computer. (Computer)
What drive letter no longer has a device listed to the left of it?
That is the drive letter you want.
Laptop off, plug the drive back in again. Turn the laptop on, and proceed with the above instructions.
No drive letter matching up to your external drive?
Post back in a Comment.
Regards,
joecoolvette
Jul 06, 2011 | Lenovo Super Multi-burner Drive (serial...
I plugged in my 32 GB Verbatim flash drive with the store n' go software. I than turned it off. When I turned the computer back on and plugged in the drive, no prompt appears to open the flash and it is...
No, windows is probably just not assigning a drive letter to the device.
check out this tutorial.
I come across this problem pretty often with pirated copies of Windows 7.
If the above doesn't work or if you get stuck just reply to this thread and I'll help :)
Jan 22, 2011 | Verbatim EACH Flash Drive, USB 2.0, 32GB,...
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't upload photos from my ge cameraonto my laptop
Try seeing if the camera is mounting as a drive using a drive letter that is already being used by something else. RIGHT click on "My Computer" pick "Manage" then "Disk Management". If the camera is there, edit the drive letter and change it to something else, like "m".
Do you have the camera off when you plug it in, then turn it on? (recommended)
Without more info, it is hard to troubleshoot. The only other suggestion is to correctly power down your computer, then unplug it. Let it sit there for a couple of minutes, then plug it back in. Sometimes motherboards need to be "rebooted", and this is how to do it. (This works sometimes for usb devices that all of a sudden become "unrecognized".)
Nov 23, 2009 | General Electric GE 10.1MP Digital Camera,...
I am not computer literate so I have this bonzia xpress and don't know what to do with it. 256mb. I know it gets inserted into the computer but I don't know what you would use it for.
It's a device known as a USB Flash Drive.
They are portable storage devices you can use to take files with you from place to place.
If you copy your documents to the flash drive, when you plug the flash drive in of a different computer, the files will be available to you on that system.
For example, I could take pictures of my trip to the Grand Canyon, copy them to a flash drive, then mail the flash drive to you and you would be able to see all of my pictures after you've inserted the flash drive into your pc.
To access the flash drive, insert it into you pc then double click on the my computer icon and you will see a drive letter assigned to the flash drive. The drive letter is "usually" F.
Jul 22, 2009 | SimpleTech 1TB SimpleDrive Pro External...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive not working
Start my right clicking on My Computer and select manage from the options. Once there click on disk management and find the name of your flash drive or see that it is the correct size. Right click on the name of the thumb drive and select change drive letter and path. Then change the letter to something like Q or a letter not being used. Sometimes that works for me at work.
Jan 13, 2009 | Computers & Internet
Computers & Internet Logo
522 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
